AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
  • 1.  AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted Jul 01, 2014 04:43 AM
    Just to check if anyone has tried to connect 2 Ethernet Port (Eth 0 and 1) of AP 135 to 2 different POE switch?
    Can I use the above method to provide sort of redundancy link? Will the above links will be in active/active or active/standby? Is this a typical setup in campus environment?
    Seems like everyone just using 1 port instead of 2 when connecting to PoE switch.\
    Appreciate your advice.
    Many thanks.
  • 2.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted Jul 01, 2014 05:55 AM
    @wai wrote:
    Just to check if anyone has tried to connect 2 Ethernet Port (Eth 0 and 1) of AP 135 to 2 different POE switch?  [Not many people deploy like this]
    Can I use the above method to provide sort of redundancy link? Will the above links will be in active/active or active/standby? Is this a typical setup in campus environment?  [Active/Standby]
    Seems like everyone just using 1 port instead of 2 when connecting to PoE switch.\ [That is because if power is lost on the first port, the whole AP has to reboot---It is not active/active]
    Many thanks.
  • 3.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted Jul 01, 2014 06:29 AM
    Thanks for the reply.
    So in normal, will both ports be supplying power to the ap?
    If it's not, then in the event the active port is down, will the 2nd Ethernet port come up automatically?
    Thanks.
  • 4.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted Jul 01, 2014 06:31 AM
    Both ports cannot supply poe to the AP at the same time.
    When one port stops supplying POE, the AP has to reboot and will then come up with the second port.
  • 5.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted Jul 01, 2014 06:36 AM
    Can I say that, On the physical view, we will only see 1 Ethernet port with its led blinking where as the 2nd Ethernet port is off even though we have enabled it.
  • 6.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted Jul 01, 2014 06:48 AM
    Correct. The AP-225 is currently the only AP that supports both ports simultaneously via LACP. (but power is still drawn from one port)
  • 7.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted May 15, 2015 12:50 AM
    Will the below be possible in the future:
    1. AP draws power from 2 ports and maintains Up status even if one port or POE from one port is down? ____
    2. Can the AP have a built-in capacitor or battery, to maintain 30 sec power, when one port or POE from one port is down? ____
  • 8.  RE: AP 135 - 2 Ethernet Ports (Use 2nd port to create redundancy)
    Posted May 15, 2015 08:09 AM
    Future APs will *likely* have two PD circuits and load share across both links.
    Tim
