last person joined: 7 hours ago
AP-135 & AP-134
  • 1.  AP-135 & AP-134
    Posted Mar 23, 2013 06:38 PM
    is the only difference that AP-134 doesnot have internal antennas & needs external antenna
    if Yes i can find multiple antennas with AP-134 , which one to use ?
  • 2.  RE: AP-135 & AP-134
    Posted Mar 23, 2013 06:52 PM
    Yes.   The radio is the same, it is just the antenna selection.   Refer to the attached configuration guide for the 130 series APs for your antenna options.   The choice of which antenna to choose comes down to the deployment requirements; indoor or outdoor, mount location, etc.
    Attachment(s)
    pdf
    CG_AP-130.pdf   318 KB 1 version
  • 3.  RE: AP-135 & AP-134
    Posted Mar 23, 2013 06:53 PM
    It all depends on the type of outdoor deployment and angle you need see if this link helps :
    http://www.arubanetworks.com/products/access-points/indoor-and-outdoor-antennas/
  • 4.  RE: AP-135 & AP-134
    Posted Mar 25, 2013 03:23 PM
    Which Antenna is bettwr for the following :
    1-indoor mounting of AP + extension cable of antenna to cover outdoor area
    2-normal Covrage ( wall mounting )
    3-normal covrerage ( ceail mounting )
  • 5.  RE: AP-135 & AP-134
    Posted Mar 25, 2013 03:50 PM
    For that type of deployment I suggest the AP-ANT-17
  • 6.  RE: AP-135 & AP-134
    Posted Mar 29, 2013 12:23 PM
    but those are difefrent deployments , why  AP-ANT-17  for all  the three deployments ?
