AP 135 is constantly rebooting.
  • 1.  AP 135 is constantly rebooting.
    Posted Jun 06, 2014 01:13 PM
    I have a AP 135 that constantly reboots. I have purged and reset it, but still get a constant reboot. The following is the output i get when connected via the console connection:
    APBoot 1.2.6.7 (build 30025)
    Built: 2011-08-30 at 17:41:16
    Model: AP-13x
    CPU: 88F6560 A0 (DDR3)
    Clock: CPU 1600MHz, L2 533MHz, SysClock 533MHz, TClock 200MHz
    DRAM: 256MB
    POST1: mem 2 (Mismatch at 00b00000: Expected ffb0ff00 got fbb0ff00) FAILED!
    Flash: 16 MB
    Power: 802.3af POE
    LAN: done
    PHY: done
    PEX 0: RC, link up, x1
    bus.dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00.00 00 11ab 6560 00005 02 f1000000 00000000 00000000 00000000
    00.01 00 168c 0030 00002 01 90000000 00000000 00000000 00000000
    PEX 1: RC, link up, x1
    01.00 00 11ab 6500 00005 02 f1000000 00000000 00000000 00000000
    01.01 00 168c 0030 00002 01 94000000 00000000 00000000 00000000
    Net: eth0, eth1
    Radio: ar9390#0, ar9390#1
    Hit <Enter> to stop autoboot: 0
    Any fixing this AP or is it time to trash it and replace it?
    #AP135
  • 2.  RE: AP 135 is constantly rebooting.
    Posted Jun 06, 2014 01:15 PM
    Looks like there may be an issue with the memory. I would initiate an RMA.
