AP 135 LED state
  • 1.  AP 135 LED state
    Posted Jan 18, 2016 06:16 PM
    Hi there.
    We are used to deploy AP135 but for the first time today we got 2 amber LED for 5 and 2.4 ghz
    I am a but confused regarding the explenation on the user manual
    Could someone give me a little hint on
    Amber 5 GHz radio enabled in WLAN mode
    5 GHz radio enabled in 11n mode
    I can understand the 11 n mode but what about the WLAN mode.. it is not so clear to me.
    Thanks.
  • 2.  RE: AP 135 LED state
    Posted Jan 18, 2016 06:56 PM
    Are these APs tied to a Controller ?
    If yes make sure that you have a Virtual-AP Assigned under the AP-Group .
    Under the SSID Profile > HT profile verify that HT is enabled
    Do you have AP licenses on the controller installed ?
    Under Configuration > AP Installation see if the AP shows up with any flags
    Sent from Outlook Mobile
  • 3.  RE: AP 135 LED state
    Posted Jan 19, 2016 07:55 AM
    YEs they are tied to a controller.
    There is indeed few VAP under the AP group
    HT is disabled because we want it that way
    and regarding the licensing it is all good (still 100 ish available)
    Thank you
  • 4.  RE: AP 135 LED state
    Posted Jan 19, 2016 08:55 AM
    It is not clearly worded.  WLAN mode just means that it is not configured as an Air Monitor or Spectrum Monitor.  It is servicing clients.  If it is Amber that means one or more SSIDs have HT disabled.
  • 5.  RE: AP 135 LED state
    Posted Jan 19, 2016 09:08 AM
    Ok , it makes sense then.
