Hello I'm trying to use a 155 as a RAP and have the USB use a modem. The Modem I'm tring to use is a Verizon MiFi 6620L but I am having problems getting it to connect correclty. If the 6620L will not work will the Verizon MiFi 620L work. Thanks!
The Novatel U620L for Verizon is defined as a supported modem on RAP-155(P) with the following minimum SW versions:
- AOS: 6.3.1.19, 6.4.4.2, 6.5.0.0, 6.5.1.0, 6.5.2.0, 8.0.1.0, 8.1.0.0
- Instant: 4.2.1.0
No mention of the 6620L
Thanks Onno,
We finally Got everything in and our WIB (Wifi in a Box) works great! Side note to everyone else. The a brand new U620L needs to be intiated on a computer first. It has a setting to set before the U620L will connect to the internet.
Is there a document that says how to provision the USB parameters on the RAP for this modem?
MiFi USB730L appears to be a newer replacement, but I haven't found a document for either that specifies the USB parameters on the RAP.
Thank You,
David
Hello Beeliada,
Here is an artical that might help.
https://www.arubanetworks.com/techdocs/ArubaOS%206_3_1_Web_Help/Content/ArubaFrameStyles/Remote_AP/Support_for_4G_USB_Modem.htm
Also I would make sure the modem work on something else first. The problem I had with mine is that I had to activate the modem on a computer before it would work. Testing it a head of time will also help you find a good location for it to connect back. It can take some time for the access point to finish connecting. When testing / upgrading the AP I'll normally plug it up were I know it has a good signal and set it sit there for about 10 minutes before going back to it.
Hope this helps.
