AP 175 configuration... bg is not working
  • 1.  AP 175 configuration... bg is not working
    Posted May 16, 2013 02:20 PM
       we Install AP 175 with 4 antennas 2005-v and h and 5005-v and h..... and AP 175 is showing up ...we have all APs are in default group and AP 105 is working fine and broadcasting SSID on 2.5 and 5 but AP 175 is not and while checking no bg channels is there..and AP is working as AM.. can any one guide me how ill configure AP 175 that it will work as other AP...
    No point to point link just for outdoor connectivity for users.......
    thanks
  • 2.  RE: AP 175 configuration... bg is not working
    Posted May 16, 2013 02:36 PM
    If you see the AP as an Air Monitor, the 802.11g radio profile is may be set as such.  Please check the following for the AP Group the AP is In:
    RF Management --> 802.11g radio
    Check the profile and check what "mode" is set.
    am-mode = Air Monitor
    ap-mode = AP (hybrid)
  • 3.  RE: AP 175 configuration... bg is not working
    Posted May 17, 2013 12:21 AM
    You can also contact TAC and they can work through the configuration with you.
  • 4.  RE: AP 175 configuration... bg is not working
    Posted May 17, 2013 04:01 AM
    Thanks for your support,
    It was a regulatory domain issue..... :-)
