AP 175 Installation
  • 1.  AP 175 Installation
    Posted Feb 02, 2012 01:24 AM
    I have Outdoor AP 175 ,when i connected  4 antennas and tested the AP the R0 is showing only one blink (RED) and R1 is showing Two Blink (blue) and the signal strength is not stable when i have tested from my laptop ,it is max then fall to good signal ,then again excellent ,, the Gain set to ap is 5 db
    anybody could help me identyifaing what is the issue
  • 2.  RE: AP 175 Installation
    Posted Feb 02, 2012 05:26 AM
    - What antennas are you using?
    - To what terminals did you connect them?
    - Are you using the AP175 to serve clients, do mesh, or both?
  • 3.  RE: AP 175 Installation
    Posted Feb 02, 2012 12:22 PM
    Need more information.
    What tests did you run?
    Red color typically means the radio has no any connection. Blue color typically means the radio has some connections.
    If the signal is not stable, please check your antenna type and connection first.
