AP-175P stand alone AP
  • 1.  AP-175P stand alone AP
    Posted Nov 01, 2014 06:01 AM
    I am new on aruba products and I have a Aruba AP-175P, Im trying to make this as a stand alone AP  without the controller. Is it  possible to make this AP-175P as a Instant AP? or any firmware to make this as an IAP-175P? below are some details of my AP-175P. Thanks..
    APBoot 1.2.2.16 (build 26085)
    Built: 2010-11-15 at 10:47:17
    Model: AP-175X
    CPU: AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 16 MB
    apboot> mfginfo
    Manufacturing info:
    System S/N : AY0001575
    Date Code : 020911
    Base MAC : 00:24:6c:cd:86:26
    MAC Count : 1
    CPU Assembly : MSR2K2SE
    CPU Major Rev : A0
    CPU Brd Variant : 00
    CPU Board S/N : 110700175
    PROM Format : 1
    Checksum : 34
  • 2.  RE: AP-175P stand alone AP
    Posted Nov 01, 2014 08:17 AM
    It is not possible to convert a campus based AP model to an IAP; only IAP to campus.  If the part number is not IAP-175x, then you cannot run Instant software on it.
  • 3.  RE: AP-175P stand alone AP
    Posted Nov 03, 2014 01:46 PM
    Hi Loyd
    Unfortunately you can't convert a campus AP into an Instant AP. It only works the other way around
  • 4.  RE: AP-175P stand alone AP
    Posted Nov 03, 2014 02:08 PM
    Hello Trav,
    Thanks for the reply.. Is there other way to work this AP without the controller? If have.. please share to me the procedure.. Thanks..
