Shall i need to configure GRE IP if we are using AP 205 to get the AC speed?
Please share the GRE config
Thank you...
Nik..
No, you do not. The AP-205 only has one port. The GRE striping is for LAGs to the AP.
Thanks Tim for quick reply...
What is GRE config for AP 225?
Thank you..
http://www.arubanetworks.com/techdocs/ArubaOS%206_3_1_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/AP_Config/LACP_Support_on_AP_220.htm?Highlight=striping
