Aruba Airwave
last person joined: 7 days ago
AP 205 only allowing 1 client
  • 1.  AP 205 only allowing 1 client
    Posted Sep 28, 2023 03:28 PM
    Hi
    apologies as this would have been covered but I cant find it :)
     I have a small network most offices have an ap 205 or similar in each, only we are finding that we can only use 5 clients and there is limited access to the internet, not sure where to look to find solution. have a central controller
    TIA Adrian
  • 2.  RE: AP 205 only allowing 1 client
    Posted Sep 29, 2023 09:30 AM
    Hi Adrian,
    so this is not an Airwave issue - if possible choose the correct section ("Wireless Access") for controller based WLAN.
    And pls. provide addtional infos, at least the AOS-version you are using and maybe some more information about your setup (type of authentication, etc.)
    /Jochem
