AP-205H
  • 1.  AP-205H
    Posted Feb 05, 2016 10:48 AM
    Is there any secret to programming the Ethernet 1 and 2 ports? We installed a couple and were thinking of using the ethernet ports for some of our employees laptops but we can't even get a packet from the AP. The wireless part of the AP is working perfectly... Any suggestions?
  • 2.  RE: AP-205H
    Posted Feb 05, 2016 10:50 AM
    Did you configure the interfaces in the AP section of the group configuration?
  • 3.  RE: AP-205H
    Posted Feb 05, 2016 10:51 AM
    Are you using it in IAP or Campus mode ?
  • 4.  RE: AP-205H
    Posted Feb 05, 2016 10:53 AM
    That is not a secret :-)
    You need to configure the wired-port-profile and wired-ap-profile for the enet port.
    Rajaguru Vincent
  • 5.  RE: AP-205H
    Posted Feb 05, 2016 11:01 AM
    We have it set to IAP mode. We have an AP group specifically for these APs and under the the group is where the Ethernet interface 2 port configuration settings are.
  • 6.  RE: AP-205H
    Posted Feb 05, 2016 11:06 AM
    What specifically is not working for you?
    And what are you trying to accomplish ?
  • 7.  RE: AP-205H
    Posted Feb 05, 2016 11:10 AM
    We have a LAN jack in an office that would like to also have wireless. We bought an AP-205H. We would like to install the AP on the electrical box and use the eithernet ports for her desktop. The wireless connectivity works fine but neither of the ethernet ports are working. We programmed them to be a bridge with access mode set..
