Hi community,
What is the function or role of the different Ethernet ports in AP-205H? I am clear that E1-E3 ports are the downlinks, and E0 is the uplink, but which E0 specifically? There is a E0 at the back, a E0/PT at the bottom and a PT port at the back. What is the relation between all of them? The AP-205H Installation Guide says:
Additionally, the IAP-205H access point has a Pass-Through (PT) port at the back (Figure 2) and an E0/PT port at the bottom (Figure 3). The E0/PT port acts primarily as a Pass-Through (PT) port. Alternatively, the E0/PT port can serve as an E0 uplink port and accepts 802.3af/802.3at PoE power when the E0 and PT ports at the back of the AP are physically bridged by an Ethernet cable.
PT is a Pass-Through port, but E0/PT is also a Pass-Through port. But what does exactly mean a Pass-Through port? I don't understand that explanation. Can you put an example? I am powering my AP-205H with a DC power source (no PoE), what port do I have to use for the uplink? E0 at the back? Or E0/PT at the bottom? Or either?
Many thanks in advance.
Julián
