AP-205H not booting as instant device
  • 1.  AP-205H not booting as instant device
    Posted Jul 26, 2016 08:54 PM
    I've got a brand new AP-205H, plug it to a PoE+ switch (switch is just for powering it up) and it never boots up.
    The "instant" ESSID is never announced (I left it plugged to the switch for over 1 hour) and the System Status LED stays blinking in green color at a slow frequency (2 times per second)
    The PSE LED stays off.
    I've tried the factory reset but it doesn't make any difference.
  • 2.  RE: AP-205H not booting as instant device
    Posted Jul 26, 2016 08:55 PM
    Is it an AP-205H or an IAP-205H?
  • 3.  RE: AP-205H not booting as instant device
    Posted Jul 26, 2016 08:57 PM
    AP-205 as per sticker on the back side.
    So, it does NOT support Instant?
  • 4.  RE: AP-205H not booting as instant device
    Posted Jul 26, 2016 08:59 PM
    That's correct.
    IAP-205H = Instant (can be converted to controller-based)
    AP-205H = controller-based only
  • 5.  RE: AP-205H not booting as instant device
    Posted Jul 26, 2016 09:02 PM
    I see.
    Thanks a lot.
