AP-207 running Officeconnect configured to Aruba Instant
  • 1.  AP-207 running Officeconnect configured to Aruba Instant
    Posted Nov 29, 2017 12:00 AM
    Hi there I have a APIN0207 access point.  It is running OfficeConnect but I would like it to run Aruba instant.  I would like to add it to a cluster of IAP-205's.  Is it possible, and how do I navigate the 207's existing UI to get somewhere that I can re-image/update firmware to Aruba instant?
    Thanks for your help.
  • 2.  RE: AP-207 running Officeconnect configured to Aruba Instant
    Posted Nov 29, 2017 12:57 AM
    No. An OC20 is a different product, even if it shares the same regulatory model number (and a lot of the hardware) with IAP-207 and AP-207 (APIN0207). It can not be converted or upgraded to run Instant.
  • 3.  RE: AP-207 running Officeconnect configured to Aruba Instant
    Posted Nov 29, 2017 05:04 PM
    Thank you for your help!
  • 4.  RE: AP-207 running Officeconnect configured to Aruba Instant
    Posted Aug 27, 2019 06:58 AM
    Hi, follow this guide, made for the HP cloud managed ap, but can be used for OC20 also, OC20 is the same harware as iap-207, so yes u can change the firmware.
    https://afp.arubanetworks.com/afp/index.php/Convert_an_HP_Cloud_AP_to_an_Aruba_Instant_AP
  • 5.  RE: AP-207 running Officeconnect configured to Aruba Instant
    Posted Sep 18, 2020 12:29 AM
    Hi Ruflow, can you give me instruction how to change the firmware? because the url not accesible..
