AP 215 / 7210 controller and VOIP
  • 1.  AP 215 / 7210 controller and VOIP
    Posted Apr 13, 2016 08:52 AM
    I'm trying to enhance our VOIP over our WiFi.  I've set the following Rules for the ports our Mitel system uses.  Is there anything else I can do to enhance the traffic?  All traffic is being tunneled back through to the controller then to the phone system.  Thanks for any thoughts.
  • 2.  RE: AP 215 / 7210 controller and VOIP
    Posted Apr 23, 2016 06:10 AM
    Are you certain that your Mitel Phones do not support SIP?
  • 3.  RE: AP 215 / 7210 controller and VOIP
    Posted Apr 25, 2016 07:45 AM
    Thanks for the repsonse.  I actually made a few network tweaks.  I noticed that the device was not connecting to the 5 GHZ network I intended it to connect to.  I made some modifications to my ARM config and lowered the 2.4 GHZ transmit powers and turned on band steering.  I also noticed that the client was using rtp to communicate back to the VOIP system.  I assigned priority to RTP for the profile the clients would have.  I also assigned port priority on my Enterasys switch where the VOIP system is plugged in.  All have seemed to help keep connection better.
