¸AP 215 always upgrading
  • 1.  ¸AP 215 always upgrading
    Posted Dec 06, 2017 03:03 PM
    Hello!  I have an AP 215 that is always rebooting.  On the controler, I can see that is in "upgrading" state.  All my others APs are OK.  Only this one.  I tried factory_reset, clear os, clear all, purgeenv...  I did the reset with paperclip.  Nothing works.
    Here is the lasts lines on the console:
    [ 56.175728] usbcore: registered new device driver usb
    [ 56.337067] usbcore: registered new interface driver usbserial
    [ 56.628100] USB Serial support registered for generic
    [ 56.688799] usbcore: registered new interface driver usbserial_generic
    [ 56.767000] usbserial: USB Serial Driver core
    [ 56.901288] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 56.979495] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [ 57.058766] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [ 57.213141] fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000
    [ 57.286926] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [ 57.353676] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 57.434974] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 57.521455] usb usb1: Product: Freescale On-Chip EHCI Host Controller
    [ 57.598563] usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
    [ 57.663171] usb usb1: SerialNumber: fsl-ehci.0
    [ 57.774644] hub 1-0:1.0: USB hub found
    [ 57.819500] hub 1-0:1.0: 1 port detected
    [ 58.147061] usbcore: registered new interface driver cdc_acm
    [ 58.214839] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
    shutting down watchdog process (nanny will restart it)...
    <<<<< Welcome to the Access Point >>>>>
    Other info:
    apboot> version
    APBoot 1.5.3.9 (build 43867)
    Built: 2014-05-21 at 19:31:10
    apboot>
    apboot> osinfo
    Partition 0:
    image type: 0
    machine type: 25
    version: 6.5.4.1
    build string: ArubaOS version 6.5.4.1 for 22x (p4build@rhodes) (gcc version 4.5.1) #61494 SMP Mon Sep 18 19:25:47 PDT 2017
    flags:
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Partition 1:
    image type: 0
    machine type: 25
    version: 6.4.1.0
    build string: ArubaOS version 6.4.1.0 for 22x (p4build@cyprus) (gcc version 4.5.1) #43882 SMP Thu May 22 14:24:44 PDT 2014
    flags: preserve factory
    Signer Cert OK
    Policy Cert OK
    Is anyone can help me?  Or I return the AP for warranty?
    Thanks!
  • 2.  RE: ¸AP 215 always upgrading
    Posted Dec 07, 2017 11:48 PM
    please attach full console log from power on until it reboots. I suspect a hardware issue with the flash or pci; the full log should show it somewhere.
  • 3.  RE: ¸AP 215 always upgrading
    Posted Dec 14, 2017 08:05 AM
    Here's full Log:
    Model: AP-21x
    CPU: P1010E, Version: 1.0, (0x80f90010)
    Core: E500, Version: 5.1, (0x80212151)
    Clock:
    CPU0: 800 MHz
    CCB: 400 MHz
    DDR: 400 MHz (800 MT/s data rate) (Asynchronous)
    LBC: unknown (LCRR[CLKDIV] = 0x00)
    L1: D-cache 32KB enabled
    I-cache 32KB enabled
    I2C: ready
    DRAM: Configuring DDR for 800 MT/s data rate
    DDR: 256 MB (DDR3, 32-bit, CL=6, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2: 256 KB enabled
    Power: 802.3at POE
    PCIe1: RC, no link
    PCIe2: RC, no link
    Net: eth0
    Radio: none
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xee000000
    Copying image from 0xee000000
    Signer Cert OK
    Policy Cert OK
    [ 0.000000] Flash variant: variant0
    [ 0.000000]
    [ 0.000000] Aruba Networks
    [ 0.000000] ArubaOS Version 6.5.4.1 (build 61494 / label #61494)
    [ 0.000000] Built by p4build@rhodes on 2017-09-18 at 19:25:47 PDT (gcc version 4.5.1)
    [ 0.000000]
    [ 0.000000] P1010 RDB board from Freescale Semiconductor
    [ 0.000000] Memory: 248728k/262144k available (10044k kernel code, 13416k reserved, 612k data, 376k bss, 6504k init)
    [ 0.001513] Brought up 1 CPUs
    [ 0.078133] PCI: Probing PCI hardware
    [ 0.121141] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [ 0.183843] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    [ 0.246191] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [ 0.320873] pci 0001:02:00.0: not setting up bridge for bus 0001:03
    [ 4.938082] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    [ 5.162188] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    [ 5.237282] Amd/Fujitsu Extended Query Table at 0x0040
    [ 5.298778] number of CFI chips: 1
    [ 5.353230] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
    [ 5.435636] gfar_probe: Renaming interface to bond0
    [ 5.494442] /proc/gfar_bond0_stats created
    [ 5.594290] Enabling watchdog on CPU 0
    [ 5.641096] caam ffe30000.crypto: device ID = 0x0a14010000000000
    [ 5.713040] caam ffe30000.crypto: job queues = 4
    [ 5.768376] caam ffe30000.crypto: authenc-hmac-sha1-cbc-aes-caam
    [ 5.840362] caam ffe30000.crypto: authenc-hmac-sha256-cbc-aes-caam
    [ 5.914430] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des3_ede-caam
    [ 5.991620] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des3_ede-caam
    [ 6.070895] caam ffe30000.crypto: authenc-hmac-sha1-cbc-des-caam
    [ 6.142875] caam ffe30000.crypto: authenc-hmac-sha256-cbc-des-caam
    [ 6.221830] caam ffe30000.crypto: ccm-aes-caam
    [ 6.319917]
    [ 6.319922] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 6.411674] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 6.530749] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 6.602700] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 6.646500]
    [ 6.692410] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
    [ 6.787716] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
    [ 6.909643] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
    [ 7.032524] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
    [ 7.155391] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
    [ 7.290223] Starting Kernel AES-CCM FIPS KAT ...Completed Kernel AES-CCM FIPS KAT
    [ 7.390573] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
    AP-type has_ble_support: USB.
    Domain Name: arubanetworks.com
    No panic info available
    ardmore: Start hotplug
    Enabling ble_daemon via nanny
    [ 16.133759] AP xml model 84, num_radios 2 (jiffies 7895)
    [ 16.197349] apType 84 hw_opmode 0
    [ 16.236958] radio 0: band 1 ant 0 max_ssid 16
    [ 16.289062] radio 1: band 0 ant 0 max_ssid 16
    [ 16.349362] init_asap_mod: installation:0
    [ 16.773256] firewall cpu: core-0
    ardmore: Copying BT modules to /tmp
    Starting watchdog process...
    Getting an IP address...
    [ 21.026457] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [ 27.031488] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
    [ 27.105561] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    192.168.54.21 255.255.255.0 192.168.54.1
    Running ADP...Done. Master is 10.54.10.71
    ardmore: Insmod BT modules
    [ 55.817061] usbcore: registered new interface driver usbfs
    [ 56.056222] usbcore: registered new interface driver hub
    [ 56.177583] usbcore: registered new device driver usb
    [ 56.335086] usbcore: registered new interface driver usbserial
    [ 56.629428] USB Serial support registered for generic
    [ 56.690142] usbcore: registered new interface driver usbserial_generic
    [ 56.768341] usbserial: USB Serial Driver core
    [ 56.902771] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 56.980984] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [ 57.060224] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [ 57.214580] fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000
    [ 57.288920] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [ 57.355669] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 57.436968] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 57.523449] usb usb1: Product: Freescale On-Chip EHCI Host Controller
    [ 57.600582] usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
    [ 57.665192] usb usb1: SerialNumber: fsl-ehci.0
    [ 57.776681] hub 1-0:1.0: USB hub found
    [ 57.821540] hub 1-0:1.0: 1 port detected
    [ 58.148465] usbcore: registered new interface driver cdc_acm
    [ 58.216228] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
  • 4.  RE: ¸AP 215 always upgrading
    Posted Dec 14, 2017 08:12 AM
    RMA it (or bin it) - PCIe interface to the radios is borked.
    yours:
    Flash: 32 MB
    L2: 256 KB enabled
    Power: 802.3at POE
    PCIe1: RC, no link       <<<<
    PCIe2: RC, no link       <<<<
    Net: eth0
    Radio: none              <<<<
    normal
    Flash: 32 MB
    L2:    256 KB enabled
    Power: 802.3af POE+
    PCIe1: RC, link up, x1
         dev fn venID devID class  rev MBAR0 <snip>
         00  00  14e4  4360 00002   03 80000004
    PCIe2: RC, link up, x1
    dev fn venID devID class  rev MBAR0 <snip> 00 00 14e4 4360 00002 03 a0000004 Net: eth0 Radio: bcm43460#0, bcm43460#1
