AP 215 Mount Kit
  • 1.  AP 215 Mount Kit
    Posted Nov 24, 2014 05:44 AM
    HI guys,
    a very simple question , which mount kit I can use to mount my 215 ap to the ceiling?
    AP-220-MNT-W2 or AP-220-MNT-W1?
    thanks in advance
    best regards
  • 2.  RE: AP 215 Mount Kit
    Posted Nov 24, 2014 08:26 AM
    Check out the ordering guide for the 210 series:  http://www.arubanetworks.com/pdf/products/OG_AP-210Series.pdf
  • 3.  RE: AP 215 Mount Kit
    Posted Nov 24, 2014 08:30 AM
    Either will work with the 215; but they are both wall mount options.  They could be used on ceilings as well.  I've attached the installation guides for the two so you can see the difference.
    Attachment(s)
    pdf
    AP-220-MNT-W1.pdf   245 KB 1 version
    pdf
    AP-220-MNT-W2.pdf   684 KB 1 version
  • 4.  RE: AP 215 Mount Kit
    Posted Nov 24, 2014 08:46 AM
    Thank you =)
