AP-215 mounted on wall
  • 1.  AP-215 mounted on wall
    Posted Jun 28, 2016 12:04 PM
    HI,
    i have to mount an ap-215 to the wall.
    I need to know what is the ideal height to positioning of the AP.
    on datasheet I don't find this information.
    Regards
    Andrea Acampa
  • 2.  RE: AP-215 mounted on wall
    Posted Jun 28, 2016 12:07 PM
    Was the design done with horizontal or vertical orientation in mind?
  • 3.  RE: AP-215 mounted on wall
    Posted Jun 29, 2016 03:26 AM
    vertical orientation.
    Regards
    Andrea Acampa
  • 4.  RE: AP-215 mounted on wall
    Posted Jul 07, 2016 11:17 AM
    You will need to figure this out based on what you are trying to do. Keep in mind the AP has a downtilt onmi antenna and you will need to account for that. We always recommend mounting on a 90 degree angle bracket if possible, even if you are close to the edge of your facility. Threaded rod is more time consuming but also a possibility.
