AP-215s can't find controller via ADP after upgrade to 6.5.4.2
  • 1.  AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:22 AM
    I was able to get version 6.5.4.2 installed on our 7030 because of the WPA2 issue and most APs came back up after a few minutes except for our 6 AP-215s.  They just keep power cycling after failing to find our controller via ADP.  The only quick solution that support has been able to offer is to program the WAPs to point to the controller manually.  I can do this easily with two of our WAPs, however, this is not a desirable solution.  I also have a packet capture if that is of interest.  Is anyone else having any trouble after this latest update?
    Attachment(s)
    zip
    ap-215.zip   17 KB 1 version
  • 2.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 11:57 AM
    I'm in a similar situation.  I upgraded and lost 3 APs connected to my 7005 controller.  I've been on the phone with TAC and they couldn't get them back because I couldn't attach a console cable to them due to where they are mounted.  TAC issued RMAs for all of my APs (2xAP225 and 1xAP325).
    If anyone knows how to recover without a console cable then please let me know... TAC was unable to find a solution.
  • 3.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 12:03 PM
    I just got off of the phone with Aruba support and they said that they know of the issue and are working on a fix.  I have sent them a packet capture of the WAPs trying to connect, the controller tech log and a log of the WAPs booting up.  I hope that they can find a fix soon as well, because I have four WAPs that are very hard to gain physical access to.
    UPDATE:  Just received a call from Aruba and the tech said that the 6.5.3.3 (this version fixes the WPA2 vulnerability too) version does not have the issue.  I'm going to upload it after hours and check it out.
  • 4.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 04:21 PM
    I tried 6.5.3.3 this morning... and my APs still don't register... I see them attempt to create the GRE tunnel but they never complete.  Then they reboot and try again.  I don't know how they can be recovered at this point since they can't seem to find the controller any longer...
  • 5.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 04:34 PM
     Sorry to hear about that njaiswal.  Now you have me worried about my update at 4:30 pm CST.  Have you tried contacting Aruba support?
    UPDATE:  I just applied the 6.5.3.3 and, like you, I am running in to the same issue.  >:-(  I really don't want to get in the cherry picker to get these 215s.
  • 6.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 05:59 PM
    That's the boat I'm in... TAC's only response was to RMA the affected APs. I have 2 of the 3 arriving tomorrow and the third arriving on the 24th.. I'm scheduling my electricians to come and swap them out... there is no way I'm climbing up a ladder to change APs mounted 18 ft high... :-/
  • 7.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 06:03 PM
    Have you tried manually configuring them to point to the controller?  That's what I'm doing, because I don't have time to wait for some replacement hardware (honestly, I feel that it's a software issue anyway).
    Terminaled into the WAP via the console port:
    setenv serverip <controller_IP>
    setenv master <controller_IP>
    saveenv
    boot
  • 8.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:19 PM
    Thanks Derick.  Unfortuantely, I'm in the same boat as you with respect to where the APs are mounted... I have no way of getting to them until I have our electricians go fetch them...
  • 9.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:10 PM
    It looks like you have the ip address for your access points statically configured.  Are they on the same VLAN as the controller?
  • 10.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:21 PM
    Yes.  My APs are on the same VLAN as the controller and I even went one step further by plugging them directly into the controller.  They still weren't able to connect to it...
  • 11.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:23 PM
    Is there anything blocking  broadcast multicast on your switches or on the wired interface of your controller?  Again, if you enabled any of those, your access points will silently fail when they reboot.  Also, what is the output of "show adp counters"?
  • 12.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:25 PM
    I don't believe so... I have left those settings to the default value...
    Below is the output of the command you asked me to run...
    (Master) #show adp counters
    ADP Counters
    key           value
    IGMP Join Tx  1
    IGMP Drop Tx  0
    ADP Tx        13413
    ADP Rx        13413
  • 13.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:28 PM
    Type "show switch ip".  Is it on the same VLAN as the access points?
  • 14.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:37 PM
    The controller is on the same VLAN as the APs.
    Below is the output of the command...
    (Master) #show switch ip
    Switch IP Address: 192.168.25.2
    Switch IP is configured to be Vlan Interface: 1
    Switch IPv6 address is not configured.
  • 15.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:43 PM
    According to your console output, your access points are configured on a different VLAN:
    Bonding mode set to
    10.10.1.165 255.255.240.0 10.10.1.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    10.10.1.165 is the access point's ip address.  If it cannot route to 192.168.25.2 through 10.10.1.1, it will NOT find the controller.  If you are using ADP, the controller will respond with it's controller- ip address and send your access points to that.  You can change the controller ip address to something on the 10.10.1.x subnet with via a console cable (might require a reboot) and see if your access points find the controller.
    EDIT:
    You would do it like this:
    (Aruba7660-US) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (Aruba7660-US) (config) #controller-ip <new ip address of controller>
  • 16.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:44 PM
    Hi Colin,
    I believe you're looking at the wrong case... my network doesn't have any 10.x.x.x IPs in it...
    Niten
  • 17.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:47 PM
    Niten,
    You need to get a console cable like the person who opened this thread to understand what is going on.  You can type "show log system 50" to also see if there is a clue about why the access points are not connecting.
  • 18.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:49 PM
    Hey Colin,
     No doubt.  But even with the console cable, I wouldn't be able to do anything with it until the electricians show up to unmount the APs from the ceiling... they're 17 feet in the air... :-(
    Niten
  • 19.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:51 PM
    Are your access points statically configured?  Type "show log system 50" to see if there is a clue why they are not coming up...
  • 20.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:53 PM
    It appears that the access points can't create the GRE tunnel.  When I look at the datapath session table I see protocol 17 but not protocol 47...
    (Master) #show log system 50
    Oct 17 07:19:18 :399899:  <4063> <INFO> |ipstm|  sapi_rsp, sapi.c:248: SAPI response service/level lookup failed
    Oct 17 07:19:18 :348306:  <4063> <DBUG> |ipstm|  papi_rcv_cb, Recvd PAPI Message, len=88
    Oct 17 07:19:18 :348306:  <4063> <DBUG> |ipstm|  papi_rcv_cb, Recvd PAPI Message from IKE
    Oct 17 07:19:18 :348306:  <4063> <DBUG> |ipstm|  procIkeMessage, Received Unknown IKE message
    Oct 17 07:19:19 :348306:  <4063> <DBUG> |ipstm|  papi_rcv_cb, Recvd PAPI Message, len=88
    Oct 17 07:19:19 :348306:  <4063> <DBUG> |ipstm|  papi_rcv_cb, Recvd PAPI Message from IKE
    Oct 17 07:19:19 :348306:  <4063> <DBUG> |ipstm|  procIkeMessage, Received Unknown IKE message
    Oct 17 07:19:19  KERNEL: [  306.867000]   0:alloc_vis_map: Allocated 7340032 bytes for fw_visibility(3975)
    Oct 17 07:19:19  KERNEL: [  306.867000]   0:apsd_porf_getdmamem: physical address 0xB7000000, virtual address 0xc0000000b7000000, size 7340032
  • 21.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:54 PM
    Here's the output from the datapath command...
    Source IP       Destination IP  Prot SPort DPort  Cntr    Prio ToS Age Destination TAge Packets    Bytes      Flags
    192.168.25.3    239.0.82.11     17   54532 8200   0/0     0    0   1   0/0/1       17   10         400        FC
    255.255.255.255 192.168.25.3    17   8200  54532  0/0     0    0   1   0/0/1       17   0          0          FY
    192.168.25.3    255.255.255.255 17   54532 8200   0/0     0    0   1   0/0/1       17   10         400        FC
    (Master) #show datapath session table 192.168.25.3
           Q - Real-Time Quality analysis
           E - Media Deep Inspect, G - media signal
           r - Route Nexthop
           A - Application Firewall Inspect
           B - Permanent, O - Openflow
    255.255.255.255 192.168.25.3    17   8200  54532  0/0     0    0   1   0/0/1       18   0          0          FY
    192.168.25.3    255.255.255.255 17   54532 8200   0/0     0    0   1   0/0/1       18   10         400        FC
           r - Route Nexthop
    255.255.255.255 192.168.25.3    17   8200  54532  0/0     0    0   1   0/0/1       1a   0          0          FY
    192.168.25.3    255.255.255.255 17   54532 8200   0/0     0    0   1   0/0/1       1a   10         400        FC
           r - Route Nexthop
    255.255.255.255 192.168.25.3    17   8200  54532  0/0     0    0   1   0/0/1       1e   0          0          FY
    192.168.25.3    255.255.255.255 17   54532 8200   0/0     0    0   1   0/0/1       1e   10         400        FC
  • 22.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:56 PM
    It looks like the access points are not setting up CPSEC.  Again, are your access points statically configured?  Protocol 17 is just UDP.
    You should type "show log security 50 to see if there is another issue.
  • 23.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:58 PM
    Hi... sorry.. My APs are all statically configured.  192.168.25.3-.5.  My controller is 192.168.25.2.
    (Master) #show log security 50
    Oct 17 07:17:35 :103093:  <3596> <WARN> |ike|   Starting cryptoPOST
    Oct 17 07:17:50 :136008:  <4151> <DBUG> |survival|  init_rdwrap(): Max Number of users in RAD-DB:4096.
  • 24.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 10:23 PM
    I would be guessing without the AP console output.  When you get those access points down, the first thing you should do is make them DHCP.  It will make your life easier.  If you feel like it, paste the console output into here, when you get it so we can understand what might be going on.  I am assuming you opened a TAC case,
  • 25.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 10:26 PM
    Will do and yes.  I already have cases open with TAC... they've RMA'd my APs and are sending new ones...
    Niten
  • 26.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Niten,
    Please post back and let us know how it turns out.
  • 27.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 21, 2017 12:55 AM
    Hey Colin,
    So I was able to get my APs down today and have my AP325 attached to a console cable... below is the output the AP is generating when booting....
    APBoot 1.5.5.5 (build 55373)
    Built: 2016-06-09 at 11:36:40
    Model: AP-32x
    DRAM: 235 MB
    SF: Detected MX25U3235F with page size 64 kB, total 4 MB
    Flash: 4 MB
    NAND: 132 MiB
    PCIE0: link up
    PCIE1: link up
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0040 00002 00 00000004 00000000 00000000 00000000
    Power: 802.3at POE
    In: serial
    Out: serial
    Err: serial
    Net: eth0, eth1
    Radio: qca9990#0, qca9990#1
    Reset: cold
    FIPS: passed
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0x0
    Copying image from 0x44000000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [ 0.000000]
    [ 0.000000] Aruba Networks
    [ 0.000000] ArubaOS Version 6.5.4.2 (build 61807 / label #61807)
    [ 0.000000] Built by p4build@lesbos on 2017-10-07 at 01:34:34 PDT (gcc versio n 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) )
    [ 0.000000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [ 0.000000] Machine: IPQ806X wave-2 board
    [ 0.000000] Flash variant: default
    [ 0.000000] msm_reserve_memory: 0x44600000, 0x200000
    [ 0.000000] Memory policy: ECC disabled, Data cache writealloc
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 58154
    [ 0.075538] CPU1: Booted secondary processor
    [ 0.102249] clk_tbl_nss - loaded
    [ 0.212371] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
    [ 0.212558] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
    [ 4.954545] m25p80 spi5.0: found mx25u3235f, expected s25fl512s
    [ 7.407935] Found AT97SC3203 on i2c-gpio0
    [ 7.465104] no pmic restart interrupt specified
    [ 8.104842]
    [ 8.104842] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 8.184067] Starting Kernel HMAC-SHA1 KAT ...Starting Kernel DES KAT ...Compl eted Kernel DES KAT
    [ 8.290378] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 8.334114]
    [ 8.379912] Completed Kernel HMAC-SHA1 KAT
    [ 8.429896] Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    AP-type has_ble_support: ONBOARD.
    Domain Name: arubanetworks.com
    The APBoot version: 55373
    APBoot is up to date
    Done.
    No panic info available
    Writing /dev/ttyHSL2 into /tmp/ble_port
    Enabling ble_daemon via nanny
    [ 12.407372] nss_driver - fw of size 391744 bytes copied to load addr: 400000 00, nss_id : 0
    [ 12.516526] nss_driver - Turbo Support 1
    [ 12.551046] Supported Frequencies - 110Mhz 550Mhz 733Mhz
    [ 12.621055] nss_driver - fw of size 190016 bytes copied to load addr: 408000 00, nss_id : 1
    Ethernet port 1 mode: tunnel
    WARNING: eth0 is down; using eth1 for uplink
    [ 33.411621] drvlog_mod: module license 'Proprietary' taints kernel.
    [ 33.474195] Disabling lock debugging due to kernel taint
    [ 33.567447] init_asap_mod: installation:0
    [ 33.603061] ethernet_device_event: dev eth0 is up
    [ 33.669447] firewall cpu: core-1
    [ 34.274570] ethernet_device_event: dev eth0 is changed, carrier: 0
    [ 35.492096] ethernet_device_event: dev eth0 is changed, carrier: 1
    Starting watchdog process...
    Starting update SBL2 ...
    SBL2 was updated already
    [ 36.566447] Settng Jumbo MRU 2000
    Done.
    Got all network params from APboot env. Skipping DHCP
    Static IP detected. Checking if LACP needs to be configured
    LACP setting not required. AP can ping default gateway
    192.168.25.5 255.255.255.0 192.168.25.1
    Done. Master is
    cat: /etc/syslog.conf: No such file or directory
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Unmounting UBIFS completed.
    Please stand by while rebooting the system.
    [ 137.327428] Restarting system.
    Model: AP-32x
    DRAM: 235 MB
    Flash: 4 MB
    NAND: 132 MiB
    PCIE0: link up
    PCIE1: link up
    Power: 802.3at POE
    In: serial
    Out: serial
    Err: serial
    Net: eth0, eth1
    Reset: warm
    FIPS: passed
    Signer Cert OK
    Policy Cert OK
    [ 0.000000]
    [ 0.000000] Built by p4build@lesbos on 2017-10-07 at 01:34:34 PDT (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) )
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 58154
    [ 0.102624] clk_tbl_nss - loaded
    [ 0.214276] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
    [ 0.214464] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
    [ 4.966135] m25p80 spi5.0: found mx25u3235f, expected s25fl512s
    [ 7.484067] Found AT97SC3203 on i2c-gpio0
    [ 7.542861] no pmic restart interrupt specified
    [ 8.186379]
    [ 8.186379] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 8.265573] Starting Kernel HMAC-SHA1 KAT ...Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 8.371883] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 8.415620]
    [ 8.461449] Starting Kernel AESGCM KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 8.583099] Completed Kernel AESGCM KAT
    Done.
    [ 12.458825] nss_driver - fw of size 391744 bytes copied to load addr: 40000000, nss_id : 0
    [ 12.568041] nss_driver - Turbo Support 1
    [ 12.602561] Supported Frequencies - 110Mhz 550Mhz 733Mhz
    [ 12.672571] nss_driver - fw of size 190016 bytes copied to load addr: 40800000, nss_id : 1
    [ 33.474539] drvlog_mod: module license 'Proprietary' taints kernel.
    [ 33.537113] Disabling lock debugging due to kernel taint
    [ 33.630865] init_asap_mod: installation:0
    [ 33.666416] ethernet_device_event: dev eth0 is up
    [ 33.732895] firewall cpu: core-1
    [ 34.331896] ethernet_device_event: dev eth0 is changed, carrier: 0
    [ 35.573445] ethernet_device_event: dev eth0 is changed, carrier: 1
    Done.
    [ 36.647797] Settng Jumbo MRU 2000
    Done. Master is
    [ 137.392814] Restarting system.
    Model: AP-32x
    DRAM: 235 MB
    Flash: 4 MB
    NAND: 132 MiB
    PCIE0: link up
    PCIE1: link up
    Power: 802.3at POE
    In: serial
    Out: serial
    Err: serial
  • 28.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 21, 2017 01:43 AM
    I'm packing my old APs up and sending them back... I won't be able to look at the console on them any longer.
    Hope my output helped.
    Niten
  • 29.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    It might be too late to say this, but it is a best practice to use dhcp for your access points.  If you statically IP them, if you ever wanted to reconfigure your network and you somehow remove the discovery method you first configured, the access points will be dead in the water.  If they were dhcp, they would reboot and discover the controller using any available method like DNS, dhcp option, multicast, etc with minimal effort from you.
    With that being said, what was your discovery method initially?
  • 30.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    My initial discovery method was ALD... However, I thought I manually configured them to statically point to the controller IP... I set the LMS configuration paramenter to the IP of the controller, but I guess that wasn't suffiicient...
  • 31.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 17, 2017 09:26 PM
    So, the LMS-IP is only good if the AP can find the controller after a reboot.  The AP is then redirected to the LMS-IP AFTER it finds the controller.  The LMS-IP does not survive a reboot in most circumstances.
  • 32.  RE: AP-215s can't find controller via ADP after upgrade to 6.5.4.2
    Posted Oct 25, 2017 10:50 AM
    cjoseph, sorry for the delayed response.  Yes, my controller and WAPs are on the same VLAN.  I saw the recent patch for ArubaOS to 6.5.4.3 was supposed to fix this issue.  I applied it, but since our WAPs have the old firmware on it they are still succeptible to this problem, since they can't get a firmware update from the controller.  So, the only two options that I received from the techs is to factory reset the affected WAPs or to manually assign each one the controller's IP address like I posted before.  In the future I will be using DHCP assigned IP addresses for sure, which would have prevented this issue.
