  • 1.  AP-225
    Posted Jan 15, 2016 02:23 PM
    Does the AP-225 require PoE injector to boot or will it boot without an injector if directly connected into a switch with PoE?
    Tony Maruqes
  • 2.  RE: AP-225
    Posted Jan 15, 2016 02:25 PM
    It will boot with either an injector or POE.
  • 3.  RE: AP-225
    Posted Jan 15, 2016 02:32 PM
    Thanks!!! The ordering guide (http://www.arubanetworks.com/assets/og/OG_AP-220.pdf) says "Add PoE injector or AC adaptor", so that threw me off and figured I'd get confirmation from the gurus.
  • 4.  RE: AP-225
    Posted Jan 15, 2016 02:26 PM
    Injectors are only required if your switch does not provide PoE.
