Dear All,
can we use the second Ethernet Port of the AP 225 and 275 as an uplink to other AP , or we can just use it for aggeregation ?
Regards
Hi caplari,
thank you for the feedback,
but please tell me i can't or i should not ?!
thank you for the replay , yes it was designed for Aggergation with LACP , with that the AP will support up to 2 Gbps uplink wich can handle the traffic (1,3 Gbps +300 Mbps ).
but i need to know if it is possible or not :).
