I currently have a solid amber light on my 5GHz LED, and according to Aruba documentation this means that it's in non HT WLAN mode. What config changes do I need to make to place it in HT WLAN mode? I've already enabled Very High Throughput in the High-throughput SSID profile, but that doesn't seen to work. Any suggstions?
Did you check under the RF profile ?
Yes, everthing HT is checked, yet the 5 GHz light remains amber.
if you do a show ap active | include <ap name>, what do you see ?
11a Ch/EIRP/MaxEIRP ---- ----- ---------- ----------- AP:HT:140/15/22.5
Here's the output from the show ap active cmd
