AP-225 in Powersave mode performance
  • 1.  AP-225 in Powersave mode performance
    Posted Dec 18, 2014 11:13 AM
    We ave recently deployed AP-225s and we are running a combination of 225s, 135s and 125s.
    Some of these new AP-225s are running in PowerSaver mode (orange light). I am wondering if there could be a wireless performance issue or not full wireless capabilities of the AP is running in powersaver mode.
    Our switches are Catalyst 6500 with POE support (not POE+ or upoe). I am wondering if this could be causing the switch to go in power saver mode. My main concern is the wireless performance in this mode. Can anyone suggest if this is OK or I need to do something?
    #AP225
  • 2.  RE: AP-225 in Powersave mode performance
    Posted Dec 18, 2014 11:43 AM
    You should be fine. 5G is not effected and most 2.4 devices will not take advantage of 3 spatial streams.
  • 3.  RE: AP-225 in Powersave mode performance
    Posted Dec 18, 2014 01:21 PM
    in powersave mode your 2.4ghz radio will be limited to 1x3 mimo. your 5ghz won't be affected
  • 4.  RE: AP-225 in Powersave mode performance
    Posted Dec 18, 2014 10:53 PM
    Check to see if both your 2.4 and 5ghz radio are active. I believe with the 225 you will need 802.3at, PoE+ to power both radios and full functionality.
  • 5.  RE: AP-225 in Powersave mode performance
    Posted Dec 19, 2014 12:19 PM
    From the documentation,
    "Internal AP power optimization allows for increased functionality in the AP-220 Series when powered over 802.3af power. Starting in ArubaOS 6.3.1, the AP-220 Series will have full 802.11ac functionality when powered over 802.3af power. On standard 802.3af power, the USB port and second Ethernet port will be disabled. The 2.4 GHz radio runs with a single stream. The 5 GHz 11ac radio runs with full functionality. All features of the AP-220 Series functions on
    802.3at or POE+ power."
    We get support calls any time an AP enters the low power state. It seems to degrade service quite a bit in our environment.
  • 6.  RE: AP-225 in Powersave mode performance
    Posted Dec 18, 2014 10:55 PM
    Odd, when I viewed this on the Airheads app it didn't show that anyone else had replied yet. Sorry for the "me too" post
  • 7.  RE: AP-225 in Powersave mode performance
    Posted Apr 17, 2015 03:42 AM
    Yes, I have the problem too, but my switch support POE+, which is strange that the AP can only work with power saving mode. Any one can help me?
  • 8.  RE: AP-225 in Powersave mode performance
    Posted Apr 17, 2015 05:26 AM
    Cartman,
    What is your problem?
  • 9.  RE: AP-225 in Powersave mode performance
    Posted Apr 19, 2015 10:20 PM
    Hi, I have 6 AP225 APs with AC7005-RW controller, they are connected to a Huawei Switch S5700-24TP-PWR-SI. the switch support poe+ mode
    My problem is that some APs are working under power saving mode sometimes. I have no idea what's going on, because all configurations are the same.
    #AP225
  • 10.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 02:55 AM
    Cartman,
    How do you know they are not at full power?  Does the Huawei switch say how much power they are drawing?  Does the access point say they are not at full power?
  • 11.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 03:02 AM
    1, From AP front LED, the power light is amber.
    2, From AP power status, it shows poe-AF... about operational state
    3, From Switch monitor page, it shows only 9w power is used.
  • 12.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 03:18 AM
    Cartman,
    Did you open a TAC case so ensure that your configuration is correct and there is not some incompatibility between the AP225 and the Huawei switch?
    #AP225
  • 13.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 03:23 AM
    I'm not sure if i have efficient authorization to open a case. also I'm thinking about the compatible issue.
    Till now no good solution.
  • 14.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 03:31 AM
    Cartman,
    Did you try enabling LLDP on any of the ports?  http://support.huawei.com/enterprise/docinforeader.action?contentId=DOC1000019448&partNo=100112
  • 15.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 03:47 AM
    I have enable the LLDP on my switch S5700-24TP-PWR-SI, but the strange thing is the LLDP Negotiated POE power is only 0.2w, this is I find from AC about AP power status.
  • 16.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 03:49 AM
    What version of ArubaOS are you running?
  • 17.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 04:01 AM
    Hi ,  it is 6.4.1.0
  • 18.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 07:30 AM
    Is there any way you can upgrade at some point? Here is a poe big fixed in 6.4.1.1
  • 19.  RE: AP-225 in Powersave mode performance
    Posted Apr 20, 2015 09:11 PM
    Hi, So the update include the fix to my problem? i will try with that.
  • 20.  RE: AP-225 in Powersave mode performance
    Posted Apr 21, 2015 12:51 AM
    It *might* help.  It could not hurt.
  • 21.  RE: AP-225 in Powersave mode performance
    Posted Apr 21, 2015 01:31 AM
    Ok, I will try within these days. Thank you!
  • 22.  RE: AP-225 in Powersave mode performance
    Posted Jan 08, 2016 02:57 PM
    Did you find a resolution to this?  I'm having the same problem, though my Cisco switch does not have LLDP configured.
  • 23.  RE: AP-225 in Powersave mode performance
    Posted Sep 12, 2016 05:19 PM
    I had similar issue using Avaya 4850 switches.
    issue ended up being the LLDP command limiting power to individual ports.
    this is the command from Avaya CLI that limited ports to 802.3af
    no lldp tx-tlv port 1/ALL,2/ALL dot3 mdi-power-support
    Once command was disabled, AP's started functioning at full power. Power LED changed to green. AP did not need to be rebooted.
  • 24.  RE: AP-225 in Powersave mode performance
    Posted Apr 17, 2015 10:12 AM
    Common causes-
    Using the wrong size power cable on your switch
    Maxing out the spower supply on the switch
    Layer one problems with calbing
