AP-225 licensing
  • 1.  AP-225 licensing
    Posted Oct 07, 2013 10:19 AM
    I wasn't able to find this answer by searching.
    Is it true that if one is using both uplinks on an AP-225 that two AP licenses are requried?  What about other software like firewall?
    TIA.
  • 2.  RE: AP-225 licensing
    Posted Oct 07, 2013 10:22 AM
    There are no license changes for using both ports on the 225 which will be supported in AOS 6.3.1.
  • 3.  RE: AP-225 licensing
    Posted Oct 07, 2013 10:54 AM
    Do you know if it the 225, with two uplinks, is counted as two APs with respect to the Max. number of APs the controller can manage?
  • 4.  RE: AP-225 licensing
    Posted Oct 07, 2013 11:06 AM
    The controller is seeing it as one AP. Your counts shouldn't change.
