AP-225 pass through operation
  • 1.  AP-225 pass through operation
    Posted Apr 02, 2014 11:20 AM
    Does the AP-225 support pass through operation on the wired Ethernet ports similar to how this exists on the AP-125, for example?
    I realize that doing this would defeat full 802.11ac capacity requirements, but this would be acceptable in order to start our deployment in areas that only have one wire drop.  Cabling would then be upgraded at a later point.
  • 2.  RE: AP-225 pass through operation
    Posted Apr 02, 2014 11:22 AM
    Yes, you can use the second port as an access port as long as .at power is being supplied to the access point.
  • 3.  RE: AP-225 pass through operation
    Posted Apr 02, 2014 11:29 AM
    Great - thanks for the info Tim.  I couldn't be completely clear about it from the data sheets.
