AP-225 Poe Issue
  • 1.  AP-225 Poe Issue
    Posted Nov 26, 2014 07:27 AM
    Hi folks,
    We have a issue on a AP-225, some APs works in the "efficient mode"  like if these are powered by PoE af, our switches can delivered Poe at.
    We have execute the followinf command :
    #show ap debug system-status | begin Power
    Power Status
    Operational State POE: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    Current HW State POE: No restrictions
    LLDP Negotiated POE Power 0.0W
    What is the difference between Operational State Poe and Current HW State Poe ?
    have you an idea what we have O watt LLDP Negotiated for the Poe Power ?
    Thanks folks !
    Yann
    #AP225
  • 2.  RE: AP-225 Poe Issue
    Posted Nov 26, 2014 10:00 AM
    Do you have LLDP turned on the switch port? The AP uses this to negotiate power.
  • 3.  RE: AP-225 Poe Issue
    Posted Nov 27, 2014 03:37 AM
    Hi tsd25108,
    Thanks you for your answer, we have activate thhe LLDP on the port of the switch, now the output of the cmd line :
    Power Status
    Operational State POE: No restrictions
    LLDP Negotiated POE Power 0.2W
    I think it's Ok, but do you know if it's normal to get 0,2W on LLDP negotiated POE ?
    Yann
  • 4.  RE: AP-225 Poe Issue
    Posted Nov 27, 2014 08:13 PM
    Ours show 25W.  Check on the switch and see if it agrees.  Could just be a cosmetic problem in displaying the value in the debug output.  Actually the debug output is formatted differently than what you pasted, so I assume you are on a different ArubaOS rev.
