AP 225 port redundancy
  • 1.  AP 225 port redundancy
    Posted Dec 25, 2015 03:13 AM
    Hi All, To provide port redundancy to AP 225 do I need to configure " gre stripping ip" on ap system profile ? or configuring LACP on AP access switch will we enough . any suggestion will be appreciated.
    #AP225
  • 2.  RE: AP 225 port redundancy
    Posted Dec 25, 2015 07:51 AM
    By default, if you plug an AP225 into two POE port, it will boot up on the  the first switch to provide it POE.  It will not draw any power from the second port.  If at any time POE is interrupted to the AP on that  first port, it will reboot and come up on the second port that provides it POE.  You cannot avoid the reboot.
    LACP and GRE striping are not related to redundancy; they are configured when you want additional throughput.  As a practical matter, due to protocol overhead and contention, there are few instances when the actual wired sustained throughput of an AP225 would approach or even exceed the single gigabit port that it is connected to.
  • 3.  RE: AP 225 port redundancy
    Posted Dec 25, 2015 08:05 AM
    So there is no need to configure lacp on ap uplink access switch to provide redundancy.
    Am I right?
    Sent from Outlook Mail for Windows 10 phone
  • 4.  RE: AP 225 port redundancy
    Posted Dec 25, 2015 08:12 AM
    There is no need, no.
