AP-225 power status
  • 1.  AP-225 power status
    Posted Oct 21, 2014 10:05 AM
    Hi Airheads experts!
    I know there are a limitations at ap-225 if the the ap get af power (2,4 GHz 1x1, disable secondary ethernet and usb port).
    If I turn off 5 GHz radio (disable radio) Can I use 2,4 GHz radio with 3x3 MIMO. Is it possible?
    We don't have 5 GHz clients!
    I try to disable 5 GHz radio but I don't see any changes.
  • 2.  RE: AP-225 power status
    Posted Oct 21, 2014 09:58 PM
    The power change on the 220 series is standard regardless of what changes are made. If full at power isn't available via the switch you can always buy an at injector and disable PoE on the switch port.
