AP 225 power usage
  • 1.  AP 225 power usage
    Posted Mar 22, 2016 08:00 PM
    Hello
    I was reading the data sheet i know the AP 225 is poe+
    But let say im not using the USB and im just just one port of the AP
    I read on the datasheet this
     Worst-case power consumption from the AP (excluding power drawn by an attached USB device):
    - In restricted mode (PoE): 13.5W
    - In unrestricted mode (PoE): 17W
    - In unrestricted mode (DC): 15.5W
    Does this mean that the AP 225 will use all his streams 3x3 in 2.4ghz and 5ghz  17 W?  i mean the AP wont go in conservative mode in which  you will see the PWR led going orage which means that its using1×3:1SS mode  ?
    Now fallowing that logic
    I would need a switch with poe budget of 408W if i needed  to turn in all ports APS 225 without any restrictions  i mean 5ghz and 2.4ghz radios operating without restrictions
    Did i undesrtand it correctly? or did i misunderstand?
    Cheers
    Carlos
  • 2.  RE: AP 225 power usage
    Posted Mar 22, 2016 08:10 PM
    @NightShade1 wrote:
    Hello
    Does this mean that the AP 225 will use all his streams 3x3 in 2.4ghz and 5ghz  17 W?  i mean the AP wont go in conservative mode in which  you will see the PWR led going orage which means that its using1×3:1SS mode  ?  YES
    Did i undesrtand it correctly? or did i misunderstand? YES
    Cheers
    Carlos
  • 3.  RE: AP 225 power usage
    Posted Mar 22, 2016 08:17 PM
    Nice Collin thats good to know that i only need a switch of 400W to power up at least 23 APS 225 without any restrictions! :)
    I  just wanted to be sure because if i needed 30W for each AP i would need then 690W and that swtich cost a lot more...
    This will help a lot
    Thank you man!!!! for being always here :)
    Cheers
    Carlos
