AP 225 shows Power LED as amber after upgrade to 6.5.3.3
  • 1.  AP 225 shows Power LED as amber after upgrade to 6.5.3.3
    Posted Nov 28, 2017 05:56 AM
    Hello Experts .
    i performed a software upgrade on a 7030 pair in master-standy from OS 6.4.2.9 to 6.5.3.3.
    after the customer says that he has noticed the POWER LED of the 225 ap's ( all the ap's are ap 225 ) shows up as "amber".  prior to the upgrade they were showing up as "green".
    i saw on airheads what does it mean for the Power led to go amber which is "
    Power LED goes amber instead of green when the switch port to which the AP is connected is POE (802.2af) instead of POE+ (802.2at)."
    morover the flags that i see for all the ap's controller is "A2da" , so is there anything un-usual which has occured , i am not sure ?
  • 2.  RE: AP 225 shows Power LED as amber after upgrade to 6.5.3.3
    Posted Nov 28, 2017 06:06 AM
    Typically Amber means you are not using AT power.  How are your APs being powered?
  • 3.  RE: AP 225 shows Power LED as amber after upgrade to 6.5.3.3
    Posted Nov 29, 2017 11:13 AM
    hi there, thanks for confirming this to me.  i was concerned if this could be an issue.
    i already have asked the customer to check this.
