AP-225 split tunneling showing with Invalid (I) Flag
  • 1.  AP-225 split tunneling showing with Invalid (I) Flag
    Posted Feb 09, 2015 01:02 PM
    I've setup AP profile for split tunneling and it's showing with Invalid (I) Flag on Controller, see config below. When I change forward-mode to 'tunnel' all is fine (except split tunneling doesnt work lol;) Please advice
    wlan virtual-ap "Aruba-CP-Radius-vap_prof2"
    aaa-profile "Aruba-CP-Radius-aaa_prof2"
    ssid-profile "Aruba-CP-Radius-ssid_prof2"
    vlan 176
    forward-mode split-tunnel
    aaa profile "Aruba-CP-Radius-aaa_prof2"
    authentication-dot1x "CFN-Main-dot1x"
    dot1x-default-role "split-usr"
    dot1x-server-group "CFN-RADIUS-server-grp"
    user-role split-usr
    access-list session split-acl
    ip access-list session split-acl
    any any svc-dhcp permit
    any alias Net_10.29.0.0-16 any permit
    user any any src-nat
    #AP225
  • 2.  RE: AP-225 split tunneling showing with Invalid (I) Flag
    Posted Feb 09, 2015 01:07 PM
    Do you AP configured as RAP or CAP ? Does your AP connected from remote-site/other network ?
    if it working as CAP , Split tunneling isnt possible
  • 3.  RE: AP-225 split tunneling showing with Invalid (I) Flag
    Posted Feb 09, 2015 01:08 PM
    Split-tunnel is only possible if the AP is configured as a RAP.
    Tunnel, bridge and decrypt-tunnel are available when operating as a campus AP.
  • 4.  RE: AP-225 split tunneling showing with Invalid (I) Flag
    Posted Feb 09, 2015 01:29 PM
    Yes, it's CAP...so does it mean I have to change to RAP and then set IKE PSK ? Does RAP connect to controller public IP or  private IP (in my case it's IPsec tunnel from my home remote network to DC firewall - so AP to Controller communication is thru IPsec). I'm not sure what decrypt-tunnel is for
    vlan 176 (id 176) is on controller side
    (Aruba-7210) #show vlan 176
    VLAN CONFIGURATION
    VLAN Description Ports AAA Profile
    176 VLAN0176 GE0/0/0 N/A
  • 5.  RE: AP-225 split tunneling showing with Invalid (I) Flag
    Posted Feb 09, 2015 01:09 PM
    Is that a name VLAN ?
