AP 225 with DC adapter in non-HT WLAN mode
  • 1.  AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 05, 2016 03:02 PM
    AP 225 is non-HT WLAN mode when powered with DC adapter (12v, 2А). When connected with POE everything OK.
    What can be wrong? Any settings have to add?
    40:e3:d6:c5:fd:22# sh ver
    ArubaOS (MODEL: 225), Version 6.4.2.6-4.1.1.6
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-05-12 at 10:54:20 PDT (build 50009) by p4build
    AP uptime is 1 hour 7 minutes 16 seconds
    Reboot Time and Cause: unknown
    40:e3:d6:c5:fd:22#
    Sergey.
  • 2.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 05, 2016 03:27 PM
    Even if there was not enough power, the 5ghz will always operate with no restrictions.
    If there were power restrictions, the 2.4ghz band would operate at 1x1 and the USB would be disabled.
    What indication do you have that it is operating in low power mode?
  • 3.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 03:53 AM
    Hi Joseph! Thanks you for reply.
    5GHz Amber - Steady. No SSID VOTE seen by clients.
    2.4GHz  Amber - Steady. No SSID VOTE seen by clients.
    I've attached full config txt file.
    Thanks!
    Sergey.
    Attachment(s)
    txt
    AP-225.txt   2 KB 1 version
  • 4.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 05:07 AM
    The config will not say anything. Please PM me the tech support.
  • 5.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 05:22 AM
    Joseph,
    See attach please.
    regards,
    Sergey.
  • 6.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 05:45 AM
    Sir,
    Your AP did not get an ip address.  Is there any way to have DHCP supplied to that AP?
  • 7.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 05:52 AM
    Joseph,
    This AP is in the standalone application used. Just to connect some laptops via WIFI.
    regards,
    Sergey.
  • 8.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 05:58 AM
    Okay.
    I would consider upgrading the AP to the latest GA code.  It is currently showing errors on the wireless interface.
  • 9.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 06:24 AM
    Specifically I see these errors below and they have nothing to do with power.  Please try to upgrade to the latest GA code here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20377
    verflows!
    [51182.200549] wl1: 11 rx fifo 0 overflows!
    [51184.675750] wl1: 4 rx fifo 0 overflows!
    [51187.380743] wl1: 2 rx fifo 0 overflows!
    [51201.627339] wl1: 6 rx fifo 0 overflows!
    [51210.843277] wl1: 6 rx fifo 0 overflows!
    [51215.238087] wl1: 3 rx fifo 0 overflows!
    [51217.379964] wl1: 1 rx fifo 0 overflows!
    [51220.478384] wl1: 2 rx fifo 0 overflows!
    [51231.611435] wl1: 12 rx fifo 0 overflows!
    [51244.357492] wl1: 10 rx fifo 0 overflows!
    [51247.379963] wl1: 2 rx fifo 0 overflows!
    [51251.898548] wl1: 1 rx fifo 0 overflows!
    [51257.814441] wl1: 4 rx fifo 0 overflows!
  • 10.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 07:14 AM
    Joseph,
    I've upgraded AP but I have the same problem.
    ArubaOS (MODEL: 225), Version 6.4.2.6-4.1.1.11
    Compiled on 2015-11-22 at 16:41:06 PST (build 52666) by p4build
    AP uptime is 20 minutes 41 seconds
    40:e3:d6:c5:fd:22#
    New tech-support attached.
    Sergey.
    Attachment(s)
    txt
    AP-225-dc.txt   181 KB 1 version
  • 11.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 07:37 AM
    You don't have an uplink.  You have to configure the VOTE ssid to work without an uplink:
    config t
    wlan ssid-profile VOTE
    work-without-uplink
  • 12.  RE: AP 225 with DC adapter in non-HT WLAN mode
    Posted Jun 06, 2016 08:18 AM
    Thank you so much!!!
    Problem's fixed!
