Could you confirm me that the AP-270 can support concurrent operation of both radios in the same frequency band (2.4 GHz and 5
GHz).
According to the matrix (http://www.arubanetworks.com/pdf/products/MAT_AP.pdf) it's OK
Regards
Yann
While it is a dual-radio AP, you cannot put both radios in the 2.4 or 5Ghz band, one radio will be in 2.4Ghz and the other in 5Ghz only.
Ok thank you for your answer.
I think they need to modify the Access Point Matrix...
regards
