AP 274 IP66 and IP67
  • 1.  AP 274 IP66 and IP67
    Posted Mar 18, 2016 02:42 PM
    On the data sheet for the aruba AP270 series it states Chassis Rating:IP66 and IP67.  It doesnt says anything about NEMA ratings.  Its my understanding IP67 means that at a minimum it must meet NEMA 6 standards, meaning it meets the requirements im looking for.  So is the Aruba AP-274 IP67 or IP66?  is the Aruba AP-274 Nema 4x or Nema 6?  or we can skip the codes and go to the point, can the Aruba AP-274 be termporaly submerged at a very limited depth and still maintain its integrity?  Thanks!
  • 2.  RE: AP 274 IP66 and IP67
    Posted Mar 18, 2016 03:35 PM
    AP-27x are all IP66 and 67 (they are two different ratings). Should be safe to say NEMA4x (the X being for salt corrosion which we also test against).
  • 3.  RE: AP 274 IP66 and IP67
    Posted Jan 04, 2017 06:28 AM
    Is there a doccumentation with NEMA support information for 270 series APs?
  • 4.  RE: AP 274 IP66 and IP67
    Posted Jan 04, 2017 11:10 AM
    The documentation is in the datasheet where the IP ratings are stated. That is all that should be needed. IP66 and IP67 is the equivalent to NEMA4/6, and since we use all stainless hardware, and do our own salt-corrosion testing, 4X should be quivalent as well.
    http://www.siemon.com/us/standards/nema_comparison.asp
  • 5.  RE: AP 274 IP66 and IP67
    Posted Jan 10, 2019 10:50 AM
    Hi Guys..
    Not all the Aruba Access Points data sheets contains IP Rating.
    Example : ARUBA 310 SERIES and ARUBA 330 SERIES datasheets doesn't shows the IP Rating.
    More than 500 AP's installations are rejected by our client.
    Can anyone help me on this. I need IP rating for
    AP-315 (JW797A) and AP-335 (JW801A)
    This is very urgent and i am trying with all the resources (Including Sales Channel).
  • 6.  RE: AP 274 IP66 and IP67
    Posted Mar 18, 2016 04:06 PM
    Have you ever deployed AP274 in a box under ground??
  • 7.  RE: AP 274 IP66 and IP67
    Posted Mar 18, 2016 04:14 PM
    I don't know if any have been physically buried underground, but some customers have put 275 on the ground underneath enclosures/fake rocks, or inside landscape features. A 274 inside a box should be fine, and while it will work underwater, it's not recommended to be deployed that way long-term, so the box should be sealed to prevent water from filling up the box.
