There was a power problem with access point 274.
The access point has been connected via an AC interface. For unknown reasons, the point has turned off, the indicator does not light up.
We connected the power via PoE. The point has started.
Question:
Will it be right to use the point through PoE now or should I send it for repair under warranty?
At the moment, the work of the point is very important and stopping the work is causing problems.
