AP-275 802.3at fail
  • 1.  AP-275 802.3at fail
    Posted Sep 22, 2014 08:56 AM
    I have a problem with AP-275. I'm using HP procurve 2530 to connect three access points, two 225 and one 275. AP 225 are working fine but AP-275 doesn't get enough power. I have always same error:
    Sep 22 12:37:41  KERNEL(Piscina_Principal@172.16.253.5): [   87.699373] bonding: bond0: releasing backup interface eth1
    Sep 22 12:37:41  KERNEL(Piscina_Principal@172.16.253.5): [   87.788414] Disable device eth1 due to insufficient POE voltage.
    I have disconnected AP's 225, and i tried to boot with only one AP 275, but doesn't work.
    If I take a look to AP 275 Power system status I have this message:
    Power Status
    Operational StatePOE-AT: No restrictions (Overridden by LLDP)
    Current HW StatePOE-AF: Ethernet port 1 disabled; All radios disabled;
    LLDP Negotiated POE Power25.5W
    I have another HP procurve 2530 with two AP275 and no one is working. Same problem too.
    I have an Aruba controller 7210 with firmware version 6.4.2.0
    Any idea where is the problem?
    Thank you in advance.
    #7210
    #AP225
  • 2.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:19 AM
    It looks like LLDP on the HP switch is overriding what the power draw is to the AP.  Can you verify that there is an LLDP policy on the port?
  • 3.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:35 AM
    I have tried with LLDP enabled in the swtich and LLDP disabled. Doesn't work. With LLDP disabled I have this view:
    Power Status
    Operational StatePOE-AF: Ethernet port 1 disabled; All radios disabled;
    LLDP Negotiated POE Power0.0W
  • 4.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:42 AM
    This sounds like an HP switch config issue.  Please see this link as I am not an HP CLI expert :)
    http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03993001-2.pdf
  • 5.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:45 AM
    Could be, but.., shouldn't work same port configuration as for an AP225??. I have same PoE configuration in all HP procurve ports and works fine with AP-225
    #AP225
  • 6.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:50 AM
    Yes but the 225 will work with af power (negotiated)
  • 7.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:52 AM
    I take this all back.  I was just informed that we have a fix for this in 6.4.2.1 which was released Friday.  Can you please upgrade and re-test!
    Sorry about the back and forth
  • 8.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:58 AM
    Ouch...
    I will try to upgrade in a few days..
    Thank you for your help.
    Regards...
  • 9.  RE: AP-275 802.3at fail
    Posted Sep 24, 2014 04:59 AM
    I had three AP275 with this problem with AOS version 6.4.2.0
    After upgrade to 6.4.2.1 version one of those three AP-275 start working (All HP Procurve ports with same configuration).
    What I finally did to have those two AP275 working was configure HP Procurve switch this way:
    Poe-lldp-detect disable
    Poe-allocated-by-value
    Poe-value 25
    That configuraction works, so I finally have all my AP-275 working.
    Regards
  • 10.  RE: AP-275 802.3at fail
    Posted Sep 24, 2014 05:09 PM
    I tried those commands on a 2920 to no avail.  I also noticed that even though you
    invoke the "poe-lldp-detect disable" command the port still shows that as enabled.
    So, I enabled it, then configured the other two parameters, then disabled it,
    the did a power/no power and that did the trick.  Sheesh.
    That same thing worked on both WB.15.13.0005 and WB.15.11.0007
    Thanxo mucho for finding that.
  • 11.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 09:31 AM
    Hey - can you give me a little more detail on your steps? I am in the same situation - despite the disabling LLDP, my HP2530 shows it enabled. What's the power/no power mean?
    thanks!
  • 12.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 09:38 AM
    despite what I do with lldp-detect, my interface looks like:
    interface 1
    power-over-ethernet critical
    poe-allocate-by value
    poe-value 25
    exit
  • 13.  RE: AP-275 802.3at fail
    Try this:
    lldp admin-status X tx_rx
    interface X
     poe-lldp-detect enable
     poe-value 26
     no power
     power
  • 14.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 09:47 AM
    thanks, but it's still showing LLDP enabled on the gui, and the cli command file shows nothing in this area.
    One thing I noticed in the gui is Dot3 LLDP TLV and Poe LLDP-MED. I am not able to disable the former. And I can't find where that might be in the cli.
    thanks, great to be working with someone on this!
  • 15.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 09:50 AM
    ...but are the radios up after doing that and letting the AP reboot.  That is the question.
    Yes the GUI always show poe lldp detection enabled even though the default is disabled
    and no matter what you do with the setting.  Probably a bug in the GUI.
  • 16.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 10:00 AM
    actually seems a step backwards. Now after rebooting the AP-275, the controller doesn't see it.
    Status light on the AP is blinking green and the switch giu says it's current watts are 26.
    I'll let it sit like this a bit and see if it connects.
  • 17.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 10:09 AM
    Check to make sure you didn't knock your uplink port out?
    They do take a while to register as up.  You can see their real status with "show ap database"
  • 18.  RE: AP-275 802.3at fail
    Posted Sep 25, 2014 10:16 AM
    I had provisioned the AP with a name and rebooted it.
    sh ap-database now shows this with its MAC address and it shows it as down.
    Maybe I'll go with a POE injector to get it fully recognized, and then see if I can make it work with just the switch.
    pain in the neck!
  • 19.  RE: AP-275 802.3at fail
    Posted Sep 26, 2014 09:48 AM
    No joy for me so far. In fact, the 275 I had been playing with is now not recognized by the controller, even with a POE injector or connection to an Aruba switch. I'll end up consoling in and do a reset.
    It's possible that the poe "optimization" borked my 275. I rolled that change back and hadn't rebooted any other AP's.
    So for now, I have an ugly pile of POE injectors. And at $65 per, it's an irritating additional expense. But I will return to the HP switch configuration as time allows.
  • 20.  RE: AP-275 802.3at fail
    Posted Sep 26, 2014 09:51 AM
    From the description of the feature I would expect applying the PoE optimization to an AP-275 would do one of two things: refuse to apply, or render the AP useless until it is put back to normal.
  • 21.  RE: AP-275 802.3at fail
    Posted Sep 28, 2014 12:43 PM
    Thanks bjulin, the HP commands worked for me. I can confirm that the poe optimization makes the 275 non-responsive. I'm glad I found that out on a lab AP, and not on my 30 installed outdoors. The only thing that brought the lab AP back to life was an apboot>factory_reset, and the only way to accomplish that was with the micro USB console connection. To have done that up a ladder and then have to reload each AP installation would have been a giant pain.
    I suppose I need to read up on effective ways to roll-out changes. If I had poe-optimimzed and then rebooted the controller, I would have rolled this change out to all of my AP's!
    The only other challenge on an 8 ports HP 2530 is that 2 275's and 1 134 were right at the 67W power budget. I had to make the 134 "critical", one of the 275's "High" and one "low" in order to bring all three up on a switch reboot. I am investigating if there's another way to stagger port booting on this switch, because I think the problem only arises at initial power on of all 3.
    Thanks for your help!
  • 22.  RE: AP-275 802.3at fail
    Posted Sep 22, 2014 09:55 AM
    But they are working with 802.3at:
    Power Status
    Current HW StatePOE-AT: No restrictions
    LLDP Negotiated POE Power19.0W
    Same switch, same port configuration, 225 are working but AP 275 are not working. I have tried with just one AP-275 connected to avoid lack of PoE power, but doesn't work.
    Regards
