AP-275 radios not coming up
  • 1.  AP-275 radios not coming up
    Posted Sep 18, 2014 01:04 AM
    Hi
    We have 2 AP275 using with 3400 controller. the problem is that the AP is getting sync. with the controller but the radios wont comeup ( not showing the channels)and on the AP red steady LED is stowing (not blinking)
    we are using the power injectors which is PD-9001GR-AC but with no luck.
    initialy one of the AP came up but only worked for 15 mins but stopped after that. is there anything related with power ?
    #3400
  • 2.  RE: AP-275 radios not coming up
    Posted Sep 18, 2014 03:44 AM
    Hi
    I assume you have provisioned the AP's in a AP group with at least one VAP.
    Are there any flags related to the AP in the AP Installation overview?
    The controller needs to be upgraded to 6.4, but i assume this is done, otherwise you would not be seeing the AP's.
    I have witnessed something somewhat similar. In my installation, the DNS domain for the AP was different from what the aruba-master DNS record was showing.
    I'm now assuming you are using DNS as the primary solution for the AP to get hold of the controller.
    My AP-205 was experiencing much of the same when the DNS domain was wrong. The AP stayed up for longer or shorter periods, but giving med ID flags.
    Roar Fossen
    #AP205
  • 3.  RE: AP-275 radios not coming up
    Posted Sep 18, 2014 04:04 AM
    Hi
    Take a look at this post aswell
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP275-Radio-disabled-due-to-low-power/td-p/164892
    Seems to be an issue with AP-275 and power consumption.
    You might need to enable LLDP on the switch.
    Roar Fossen
