AP-277 Minimum OS version
  • 1.  AP-277 Minimum OS version
    Posted Jun 20, 2017 06:43 AM
    Data Sheet for AP-270 Series Access Points is stating that AP-277 requires minimum 6.4.3 ArubaOS to work.
    What are limitations of provisioning it on controller running lower version of OS (6.4.2.8, for example)? Thanks.
    NesaM
  • 2.  RE: AP-277 Minimum OS version
    Posted Jun 20, 2017 06:51 AM
    Anything lower does not have an image for that AP and it will not work.
  • 3.  RE: AP-277 Minimum OS version
    Posted Jun 20, 2017 07:00 AM
    Thanks Colin.
    NesaM
  • 4.  RE: AP-277 Minimum OS version
    Posted Jun 20, 2017 10:29 PM
    Sorry, posted from the app and hadn't seen that this was already marked as "Solved".
  • 5.  RE: AP-277 Minimum OS version
    Posted Jun 21, 2017 05:30 AM
    No worries, appreciate your reply and clarification on what you experienced. Thanks.
    NesaM
  • 6.  RE: AP-277 Minimum OS version
    Hi NesaM, We ran into that issue with the AP-277 and AP-205H on coincidentally the same version you're running. As Colin said, it won't work. The AP won't ever reach the provisioning stage or even show up in the GUI - you will however see an error log on the discovered master controller along the lines of "minimum firmware not met" and the AP will eventually reboot due to not finding a suitable controller and continue to "appear" to never show up on the controller. As a temporary measure, we statically assigned the one needed AP-277 to our test controller running the 6.4.3 code via console cable. We then ran a separate pair of controllers for the part of campus that needed 205Hs - we're finally planning on consolidating our controllers back to a single master for ArubaOS 8.
    #AirheadsMobile
