I need to submit the AP-277 radiation patterns to a regulation authority for approval.
Does Aruba Networks released the official ones? If this is the case, where can we find them?
Keep on your good work!
Here you go, zip file with 4 separate images. File name should be clear as to which pattern it applies to.
Attachment(s)
Doh, sorry about that, use this...
