AP-303H
  • 1.  AP-303H
    Posted Jul 25, 2019 04:15 PM
    i have a Aruba AP-303H Access point what has been setup and worked correctly. but after 1 week i can't access it trough it own ip adres.
    Rebooting the access point will not solve the issue.
    Also the devices which are connected to E1 and E2 arent not accessable.
    E0 is beeing used as upload port.
    When is start a ip scanner in my own network it is visable in my nnetwork. 1.PNGAlso a nas what is connected on port E1 will not be discovered during a scan. ( nas is powered on ) and runs correctly.
    this problem occurred after when i updated the ap with new firmware.
    Before that there was no issue.
    can someone help me with this issue.?
  • 2.  RE: AP-303H
    Posted Jul 25, 2019 04:33 PM
    Do you upgrade to software for instant 8.5.?
  • 3.  RE: AP-303H
    Posted Aug 03, 2019 03:43 PM
    frank thanks for your reply, sorry for my delay but i wasn't home last week.
    Yes i have updated the AP to the last new firmware.
    after that the problems started... :-(
  • 4.  RE: AP-303H
    Posted Aug 03, 2019 04:54 PM
    Did you try to SSH to it on the ip address?
  • 5.  RE: AP-303H
    Posted Aug 03, 2019 09:16 PM
    I had a similar issue on one of my 303s too. It was like it just lost its config one day. I couldn't SSH to it and the wired Ethernet ports stopped passing traffic too. I ended up factory resetting it and re-joined it to the cluster. I'm on 8.4.0.4.
  • 6.  RE: AP-303H
    Posted Aug 04, 2019 05:32 PM
    yes i have tried to SSH the ipadres but also nothing worked.
