HI
Anyone can help me to do the recommended configuration for IP-TV system to work with AP-303H.I just created IP-TV Vlan and wired AP profile in WLC then attached to eth2 profile. now the port is under IP-TV VLAN ( its getting IP for TV NW ) . But my TV is not work Well , its getting stuck every 5-10 mis.
IGMP snooping enabled on IP-TV VLAN
When i connect directly to switch its work well ( enable IGMP and query )
See the attached
network diagram for IP-TV system,![Network Diagram](https://higherlogicdownload.s3.amazonaws.com/HPE/UploadedImages/8ulccpcbTQCMl4ZWaXMz_DIAGRAM-NP-M.png)
Thanks in advance
#wireless
#AOS-CXSwitchSimulatorLab #AP303H #IPTv
#100Series #7210 #7220
Swajith lal
