AP 303H - corrupted firmware
  • 1.  AP 303H - corrupted firmware
    Posted Aug 31, 2018 05:26 AM
    Is it possible to update the firmware of the AP 303H using an USB stick? AP isn't booting (power led blinking) and I don't have the Aruba console cable.
  • 2.  RE: AP 303H - corrupted firmware
    Posted Aug 31, 2018 05:50 AM
    Did you try the reset button procedure? There is no way to load software from USB. Even if it could, you would still need to type somewhere to initiate the upgrade.
    What is the history of this device? Did it ever work?
  • 3.  RE: AP 303H - corrupted firmware
    Posted Aug 31, 2018 05:51 AM
    Did tried resetting it couple of times, but doesn't seems to boot.
