When I connect second AP to E1 port on AP-303P it does not get get POE. First AP gets poe from Aruba 2930F switch
Which Software Version are you using?
PSE Out is supported from 8.4 onwards and you have to enable it.
See attached document to enable it.
Attachment(s)
Also, make sure the AP and switch negotiate 802.3at (class 4) or 802.3bt (class 5) POE. With 802.3af POE, there's no POE-PSE (out) from the AP-303P.
