AP-305 - Cannot Connect after changing to mode standalone
  • 1.  AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 13, 2020 07:58 AM
    I'm having an authentication problem on an AP-305 (RW).
    This problem appears in the following situations:
    1/ When I convert the AP to standalone mode...
    2/ When I modify for example the name of the AP and after its restart.
    I've tried to fill in all the password conbinaisations (admin, S/N, forgetme!,...), nothing works. The only thing to do to be able to reconnect again is to do a reset.
    The AP works with the Aruba 8.5.0.3_72498 OS.
    Thank you in advance for your help
    Damien
  • 2.  RE: AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 13, 2020 08:08 AM
    So you have converted it from controller based AP to Instant AP right?
    You are seeing the wireless network "SetMeUp-xx:xx:xx" being broadcasted after you did the conversion or is the AP rediscovering the controller IP again?
    You tried username admin and password as serial number of AP?
    Are there any other "instant APs" on the same management vlan as this AP?
  • 3.  RE: AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 13, 2020 08:14 AM
    Yes
    no, I no longer see the SSID "SetMeUp xxxx" after the conversion and/or when I restart the AP.
    Yes, it works after a reset, but when I convert to "standalone", the password is no longer recognized.
    No, it's the only one..
    For example, here I have just restarted the AP when I didn't configure anything and I can't connect anymore. It doesn't recognize my credentials anymore.
  • 4.  RE: AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 16, 2020 04:03 AM
    It sounds strange. Did you try to upgrade to a different firmware and test? Did you try to change the password for the admin before converting to standalone?
    If the issue persists, I suggest you open a case with TAC...
  • 5.  RE: AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 18, 2020 02:58 PM
    Hi
    I have a similar problem, I restored it from the factory and it does not publish the SSID is the same model AP 305
  • 6.  RE: AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 18, 2020 03:13 PM
    Bonjour,
    J'ai résolu mon problème en installant le firmware 8.3.0.6. Avec ce firmware, aucun soucis.
  • 7.  RE: AP-305 - Cannot Connect after changing to mode standalone
    Posted Jun 29, 2020 04:03 PM
    En fait, le problème n'est pas réglé.
    Le point d'accès bloque après avoir démarré serveur web.
    Voici l’aperçue en pièce jointe du moment ou il bloque sur "Init -----> Master"
    A ce stade, j'accède à la page d'authentification mais impossible de se connecter.
    Voici une seconde capture d'écran avec une ligne supplémentaire (en jaune). Quand cette information apparait, je peux me connecter à l'interface de management.
    Le problème apparait uniquement lorsque je modifie la configuration (par exemple changement du mot de passe, création d'un SSID, etc..).
    Si je reboot l'AP alors que la configuration est par défaut, il redémarre correctement.
    Je recontre ce problème avec différente version de firmware (ArubaInstant_Ursa_8.5.0.3_72498 , ArubaInstant_Ursa_6.5.4.11_68542)
    Quelqu'un à une idée ?
    Merci d'avance
