AP-305 system status led Powersave mode
  • 1.  AP-305 system status led Powersave mode
    Posted Apr 10, 2017 12:29 PM
    Hi, I have installed into my network 4 ap model AP-305, but only one show always system status led color "Amber-solid", i don't know why!
    The installation guide show this state how "Device Ready: Power safe mode (802.3af) ".
    do you know how this ap show always this state?
    The ap is connected to Switch HPE OfficeConnect 1920 48G PoE+ (370W), and port show power to 17%.
    can you help me, please?
  • 2.  RE: AP-305 system status led Powersave mode
    Posted Apr 10, 2017 12:35 PM
    Do you have LLDP enabled on those switchports?  That is typically how the AP negotiates higher power on that port.
  • 3.  RE: AP-305 system status led Powersave mode
    Posted Apr 10, 2017 01:16 PM
    yes, i have LLPD enable on my HP 1920, this is "status information" on switch log:
    Global LLDP local-information:
      Chassis ID         : d894-03c8-57ce
      System name        : HPE
      System description : 1920-24G-PoE+ (370W) Switch Software Version 5.20.99, Release 1114
    Copyright(c)2010-2016 Hewlett Packard Enterprise Development LP
      System capabilities supported : Bridge,Router
      System capabilities enabled   : Bridge,Router
      MED information
      Device class: Connectivity device
      (MED inventory information of master board)
      HardwareRev               : REV.A
      FirmwareRev               : 117
      SoftwareRev               : Release 1114
      SerialNum                 : CN6AGP61Q3
      Manufacturer name         : HPE
      Model name                : HPE 1920-24G-PoE+ (370W) Switch
      Asset tracking identifier : Unknown
    LLDP Operating Mode: Txrx
    Encapsulation Format: ETHII
    LLDP Polling Interval and LLDP trapping is blank
  • 4.  RE: AP-305 system status led Powersave mode
    Posted Apr 10, 2017 03:02 PM
    Can you share a show tech from one of the IAPs in this state?
  • 5.  RE: AP-305 system status led Powersave mode
    Posted Apr 10, 2017 04:25 PM
    That status can be due to operating in 802.3af reduced power mode.
    Check this thread and this section of datasheet:
    http://www.arubanetworks.com/assets/ds/DS_AP320Series.pdf
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-the-impact-of-connecting-a-AP-224-or-AP-225-to-POE-802/ta-p/176226
    show ap debug system-status | begin Power
    will tell you more!
  • 6.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 05:06 AM
    It is a limitation when use 802.3af. It reduces performance but stills operating.
    I saw this before.
  • 7.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 12:42 AM
    Please check if LLDP  is enabled on the port where AP is connected.
    Probably you might have to enable it at interface level.
  • 8.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 03:43 AM
    Hi, the LLPD is already active on my switch HP 1920, but I should enable LLPD on my aruba AP?
    in attach show tec on ap where led is amber..
    Attachment(s)
    txt
    show-tec.txt   238 KB 1 version
  • 9.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 05:14 AM
    From the logs that you have attached,
    Power Status
    Item Value
    Power Supply : POE-AF
    LLDP Power : Successfully negotiated at 17.0W
    Current Operational State : USB port enabled;
    From 300 series datasheet:
    http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
    - Unrestricted functionality with 802.3at PoE
    - When using IPM, the AP may enter power-save mode with reduced functionality when powered by an 802.3af PoE source (see details on Intelligent Power Monitoring elsewhere in this datasheet) -
    -Without IPM, the USB port is disabled when the AP is powered by an 802.3af PoE source • 
    -Maximum (worst-case) power consumption: 13W (PoE) or 11W (DC) - -Excludes power consumed by external USB device (and internal overhead); this could add up to 6.5W (PoE) or 5.5W (DC) for a 5W/1A USB device • 
  • 10.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 07:46 AM
    Hi Singla, ok, but whit my AP is it possibile for you disable IPM?
    I have installed a hp 1920 48 port switch dedicated only for my ap, and the power is not my problem!! in this switch i use only 4 port... :-)
    I have ap 305 whith this version: 6.5.1.0-4.3.1.0_57768
  • 11.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 04:54 PM
    1. i am checking internally if there is a possible method to debug LLDP on IAP.
    Couple of show commands that can be useful to share on IAP are (they are not in show tech):
    show ap debug lldp counters
    show ap debug lldp neighbor interface eth0
    show ap debug lldp state
    Are you connecting both ports or one port to switch?
    2. I have an IAP 325 on the same software working on 802.3at (no orange light) with a aruba MAS S2500.
    3. Can we look at 1920 once again and verify LLDP is correct. Please follow the steps here:
    http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c04463799-3.pdf
    Page 215 onwards or search for
    "Displaying LLDP information for a port"
  • 12.  RE: AP-305 system status led Powersave mode
    Posted Apr 11, 2017 10:29 PM
    Hi ,
    As you have mentioned , only 1 IAP is showing status light to be amber-solid & other 3 are working fine.
    Please attach the show tech from the working IAP.
  • 13.  RE: AP-305 system status led Powersave mode
    Posted Aug 04, 2017 10:36 AM
    hi
    i am a new to the community - can someone just confirm (or not) that an AP 305 running in power save mode does mean reduced performance ? I have read the 305 datasheet but it is not 100% clear to me.
    Many thanks
  • 14.  RE: AP-305 system status led Powersave mode
    Posted Aug 06, 2017 03:19 AM
    When the AP-305 is in power-save mode (802.3af POE, IPM feature disabled), the only restriction is that the USB port is disabled.
