AP-314 provisioning with AP-ANT-20W
  • 1.  AP-314 provisioning with AP-ANT-20W
    Posted Feb 07, 2019 09:26 AM
    I have some questions on provisioning for ap-314 with four AP-ANT-20W .
    cannot find solution on datasheet or from the Internet.
    mobility controler 6.5.4.10
    I try the AP wizard , but no ANT-20W in the list of antenna.
    so in the provision page for an AP314 :
    ap installation mode : indoor
    external antenna Gain, 5GHz : 0.0 ?  2.4GHz : 0.0 ?
    external antenna Polarization  5GHz and 2.4GHZ :
    0-CO-Polarized or 1-Cross-Polarized  ?
    if someone can tell me what values and choice made for this antenna model , it will be great :)
    for record , from the matrix-antenna :
    Type   Dual-band omni, direct mount
    BAND(S) 2.400 GHz - 2.500 GHz     4.900 GHz - 5.875 GHz
    PEAK GAIN          2.0 dBi                        2.0 dBi
    POLARIZATION & ELEMENT TYPE  Linear, vertical. Omnidirectional patterns at all frequencies
    BEAMWIDTH (DEGREES)  360 (H-plane) 80 (E-plane)
    VSWR < 2.0 :  1
    MAX INPUT POWER     2 watts
    regards,
  • 2.  RE: AP-314 provisioning with AP-ANT-20W
    Posted Feb 07, 2019 02:09 PM
    Gain for provisioning can be copied from the matrix or antenna datasheet.
    Assuming will be co-polarized when deployed correctly (all parallel).
  • 3.  RE: AP-314 provisioning with AP-ANT-20W
    Posted Feb 08, 2019 05:32 AM
    Thanks a lot for the answers.
    What if the antenna are moved from parallel to all directions  ?
    explanations :
    we install parallel but in a warehouse and sometime (even at +12meter from the ground ) a good pallet can touch the antennas and set them in all directions.
    Regards
  • 4.  RE: AP-314 provisioning with AP-ANT-20W
    Posted Feb 08, 2019 07:53 PM
    Then your coverage areas get messed up, and you will see reduced MIMO performance and throughput.
  • 5.  RE: AP-314 provisioning with AP-ANT-20W
    Posted Feb 13, 2019 01:08 PM
    ok .
    thanks a lot for quick and clear answers.
