AP 315's Max Speed
This thread has been viewed 16 times
  • 1.  AP 315's Max Speed
    Posted 9 days ago
    Hi ,
    The majority of the AP's we are currently running are the 315's and I noticed today that the Max Speed users are getting on 5 GHz is 400 Mbps. The documentation for the 315's states I should be getting up to 1,733 Mbps. Is there something I have configured wrong? We run Microsoft Surface Laptops for the most part with IT using Dell's. It's the same across the board though.
    Brandon
  • 2.  RE: AP 315's Max Speed
    MVP GURU
    Posted 9 days ago
    You may be seeing the speed reported for a 2 spatial stream device on a 40mhz wide channel. The "marketing speed" is a theoretical maximum. You never really see speeds like that out on the real world. See this chart for expected speed with certain combinations of RSSI/SNR (Will dictate the modulation and coding), Channel Width, and Spatial Streams: https://mcsindex.com/
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: AP 315's Max Speed
    Posted 9 days ago
    So this is normal to see regardless of the AP type?
  • 4.  RE: AP 315's Max Speed
    MVP GURU
    Posted 9 days ago
    Yes this would be a clients max speed capable on a 2 spatial stream device using a 40mhz channel with an MCS of 9. Client capabilities are shared with the Aruba APs and this is how the system calculates that value.
    Dustin Burns
  • 5.  RE: AP 315's Max Speed
    MVP GURU
    Posted 9 days ago
    FYI also you would need to get the same MCS on 2spatial streams with a 160mhz wide channel to get to the 1.7 Gbps
    Dustin Burns
