AP 325
  • 1.  AP 325
    Posted Jan 03, 2017 06:31 AM
    Happy new year!
    I have the AP 325 and the 7005 controller and I'm trying to build a lab demo. I have configured the controller based on the Aruba Bootcamp of the ACMP training manual.
    However, I am facing a problem when I connect the AP to the controller.
    Isn't it supposed to get the IP directly from the DHCP settings configured on the controller? If so how can I access the console through RJ45 cable?
  • 2.  RE: AP 325
    Posted Jan 03, 2017 07:39 AM
    Did you configured a DHCP pool for the VLAN assigned on the port the AP is connected to ?
    Get Outlook for iOS
  • 3.  RE: AP 325
    Posted Jan 03, 2017 08:05 AM
    Yes basedon the manual, one of teh VLANs I should create is VLAN 13 with ip 192.168.1.1, nat not enabled and no ports assigned and then in the dhcp settings I choose Act as a server with a network IP 192.168.1.0.
    And even when I assigned the vlan to the port where the ap is connected, the green light on the ap keeps going on and off like it's not getting an IP.
    How can I access this ap and know its IP?
  • 4.  RE: AP 325
    Posted Jan 03, 2017 08:54 AM
    You can either console into the AP or from the controller CLI you can run the show IP DHCP bindings to see the leases.
    Make sure the DHCP service is enabled as well.
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-configure-a-DHCP-server-on-the-Aruba-controller/ta-p/185894
    Get Outlook for iOS
  • 5.  RE: AP 325
    Posted Jan 03, 2017 09:23 AM
    The show ip dhcp binding command is not showing anything...
  • 6.  RE: AP 325
    Posted Jan 03, 2017 10:27 PM
    Did you follow the instructions on how to enable DHCP on the controller on the link I provided ?
  • 7.  RE: AP 325
    Posted Jan 04, 2017 03:05 AM
    I have the below showing in the dhcp window and that's what I added before from the manual. I don't know what could be missing!
  • 8.  RE: AP 325
    Posted Jan 04, 2017 06:14 AM
    Is the controller management subnet on the 192.168.1.x VLAN?
  • 9.  RE: AP 325
    Posted Jan 11, 2017 03:42 AM
    I have created a vlan 13 and made it to act as a server  in the DHCP seeting with a network 192.168.1.0 default router of 192.168.1.1 and DNS server 10.254.1.21
