AP-325 Question
  • 1.  AP-325 Question
    Posted Aug 10, 2019 10:01 PM
    Hi all,
    I have a question re: AP AP-325.. Well I suppose a few questions:
    1) What's the difference between the Aruba listed AP (JW186A) and the Aruba 325 Instant (JW327A)? As far as the data sheet is concerned, the standard AP should also be able to run in Instant mode, right?
    2) Will this AP (JW186A) work for an Instant deployment in the US?
    3) What does TAA compliance mean? I see that listed on some other models.
    Any insight would be appreciated!
    -Ryan
  • 2.  RE: AP-325 Question
    Posted Aug 10, 2019 11:13 PM
    JW327A is IAP-325 for US regulatory domain.
    JW186A is controller based AP-325
    The hardware is the same but the firmware are different, one is controller base and the other is Instant AP. You can convert the JW327A to a controller based AP but you can't convert JW186A to an Instant AP.
    TAA refers to the Trade Agreements Act and here you can find more info on it. https://www.amtgov.com/what-is-taa-compliance.html
  • 3.  RE: AP-325 Question
    Posted Aug 11, 2019 01:39 AM
    Thanks! Out of curiosity, do you know which were the first models that run both IAP and campus modes? I know the 5 series only has one SKU that does both. I thought the 3 series did as well.
  • 4.  RE: AP-325 Question
    Posted Aug 11, 2019 01:46 AM
    I think it was AP-345 which came with the unified image.
  • 5.  RE: AP-325 Question
    Posted Aug 11, 2019 11:35 AM
    Unified AP-3xx: AP-34x, AP-303(P), AP-303H(R), AP-36x, AP-37x, AP-318, AP-387.
    All AP-5xx
