  • 1.  AP 325's?
    Posted Feb 17, 2016 08:34 AM
    With the new 325's having management becons in them does anyone know how to find out the BLE MAC on them once they are on the controller?
  • 2.  RE: AP 325's?
    Posted Feb 17, 2016 08:37 AM
    show ap ble-table
  • 3.  RE: AP 325's?
    Posted Feb 17, 2016 09:44 AM
    That doesn't seem like a valid command, we are running 6.4.4.4 which is the lastest early deployment that supports these AP's
    (aruba) #show ap ?
    active                  Show APs currently registered on this switch
    allowed-channels        Show the set of allowed channels
    allowed-max-EIRP        Show max EIRP setting per country per AP type
    ap-group                Show contents of AP's group
    arm                     Show ARM Information
    assoc-throttle-counte.. Show counters related to association request
                            throttling.
    association             Show Association table for an AP
    authorization-profile   Show an AP Authorization profile
    band-steering-clients   Show Band Steering State
    blacklist-clients       Show all clients being DoSed
    blacklist-time          Show the amount of blacklist time of the STA when it
                            is blacklisted in between disconnection and
                            user-timeout
    bss-table               Show bssids of all APs registered on this switch
    bw-report               Show bandwidth allocation report for an AP
    client                  Show wireless client specific information
    config                  Show AP configuration parameters. Must specify
                            ap-name and/or ap-group and optionally essid.
  • 4.  RE: AP 325's?
    Posted Feb 17, 2016 09:53 AM
    Tim forgot a word :-)
    (Aruba7010) #show  ap debug ble-table ap-name HomeOffice-225
    BLE Device Table
    MAC                HW_Type    FW_Ver        Flags   Status  Batt(%)  RSSI  Major#  Minor#  UUID                                  Tx_Power  Last Update  Uptime
    f4:b8:5e:43:42:aa  HAWTHORNE  OAD B 1.1-27  0x0103  IAH     --       -82   1000    2333    5152554E-F99B-4A3B-86D0-947070693A78  14        1s           17h:28m:0s
    78:a5:04:58:65:9a  LS-BT1     OAD B 1.1-4   0x0003  IAH     100      -79   1000    2176    55E67D09-BED6-49D8-86D5-50E0216C4952  1         269s         13d:6h:50m:0s
    c4:be:84:1d:1f:6f  LS-BT1USB  OAD B 1.1-25  0x0003  LIA     USB      --    1000    2177    5152554E-F99B-4A3B-86D0-947070693A78  15        6s           17h:23m:0s
    78:a5:04:58:5f:bb  LS-BT1     OAD B 1.1-4   0x0003  IAH     100      -74   1000    2179    55E67D09-BED6-49D8-86D5-50E0216C4952  2         421s         5d:13h:30m:0s
    c4:be:84:1d:23:6a  LS-BT1USB  OAD B 1.1-25  0x0003  IAH     USB      -88   1000    2361    5152554E-F99B-4A3B-86D0-947070693A78  15        1s           17h:23m:30s
    6c:ec:eb:3f:be:ae  LS-BT1     OAD B 1.1-4   0x0003  IAH     100      -83   1000    2180    55E67D09-BED6-49D8-86D5-50E0216C4952  3         381s         2d:7h:0m:0s
    Total beacons:6
    APB UI:[0/NO_UPGRADE_REQD]:65535(0xffff) blks:0/0 rep:0  total:0(0x0)
    APB UI:upg_b_status-next:0x00/ooo:0x00/next2:0x00/upg_b:0x00/allrx:0x00/oooBlk:0x00/oooBlk:0x00/oooBlk:0x00
    APB UI:upg_b_status_errs-inv_upg:0x00/inv_cmd:0x00/inv_op:0x00/buf_tl:0x00/good:0x00
    APB UI:acks/ka-From APB:0x00/0x00 From app:0x00,0x00/0x00
    APB UI Clock:Start:1969-12-31 20:00:00  End:1969-12-31 20:00:00  Current:2016-02-17 10:51:36
    Note: Battery level for LS-BT1USB devices is indicated as USB.
    Note: Uptime is shown as Days hour:minute:second.
    Note: Last Update is time in seconds since last heard update.
    Status Flags:L:AP's local beacon; I:iBeacon; A: Aruba Beacon; H: Aruba HiPower Beacon
                :U:Image Upgrade Pending
  • 5.  RE: AP 325's?
    Posted Feb 17, 2016 10:09 AM
    Sorry, yes, missed a word.
    "show ap debug ble-table | include L" will show you only the local BLE radio
    inside the AP.
  • 6.  RE: AP 325's?
    Posted Apr 21, 2017 04:17 PM
    Hi All,
    Short question to the experts ... we are currently faceing issues with the first produced AP 325 with a beacon firmware version 1.1-34
    i upgrade our controller to 6.5.2 and tested if the beacon firmware
    will upgraded to 1.2-17
    Sadly this don`t work ...
    the problem is that with the old firmware the AP`s stop working after a while ... and i am now searching for a solution how could i fix this for the effected AP`s (not all are effected based on the production serial number CNC7H and below )
    every hint is welcome
    Br
    Stefan
  • 7.  RE: AP 325's?
    Posted Apr 22, 2017 06:32 AM
    You should open a TAC case so that they can determine what is really wrong.  Based on their testing, they could figure out of you have a hardware or a configuration issue and take it from there...
  • 8.  RE: AP 325's?
    Posted Feb 17, 2016 10:01 AM
    Try this one :
    (MASTER-CONTROLLER) #show ap debug ble-?
    ble-config Show config for this AP's BLE daemon
    ble-counters Show pkt counters for BLE devices seen by this AP
    ble-log Show ble debug logs for an AP
    ble-table Show stats for BLE devices seen by this AP
    ble-update-status Show config update status for BLE devices seen by this AP
    (MASTER-CONTROLLER) #show ap debug ble-table ap-name
    BLE Device Table
